Add brake fluid or have brakes flushed and filled the light has little to do with the parking brake once you have confirmed it is off . That light is telling you your brakes are not working properly this is a safety issue. If brake fluid is low and has never been filled it indicates your pads are worn. If it were mine I would in this order Have brake pads and rotors looked at if they are within specification have brake fluid flushed and filled and bled. I have my brake fluid flushed and filled every two years as brake fluid absorbs water. I can no longer monitor my pads by level though.
There is one other possibility the switch for the parking brake has failed. This is rare but not impossible.
There are two lights for brakes one is for the parking brake the other is for the whole system which is on?
