Felt like sharing some of the stuff available from bisimoto for the cr-z since i haven't really seen it posted and he has a number of parts on the website already.
i believe i linked all the parts, i may have missed one or two becuase the website is a little difficult navigate.
2010+ Honda CR-Z Coil-over kit - $1,055.99 : Bisimoto Engineering, Where Efficiency Meets Technological Perfection
2010+ Honda CR-Z Rear anti-roll bar - $239.99 : Bisimoto Engineering, Where Efficiency Meets Technological Perfection
2010+ Honda CR-Z Sport springs - $267.99 : Bisimoto Engineering, Where Efficiency Meets Technological Perfection
2MD, 2010 Honda CR-Z, Race - $750.00 : Bisimoto Engineering, Where Efficiency Meets Technological Perfection
2MS, 2010 and up Honda CR-Z - $750.00 : Bisimoto Engineering, Where Efficiency Meets Technological Perfection
Bisimoto Spec GE L15, LEA1 Intake manifold, machine finish - $549.00 : Bisimoto Engineering, Where Efficiency Meets Technological Perfection
L15 and LEA1 H beam rod set - $750.00 : Bisimoto Engineering, Where Efficiency Meets Technological Perfection
L15, L15A, LEA1 sohc heat shielding intake gasket - $48.99 : Bisimoto Engineering, Where Efficiency Meets Technological Perfection
LEA1 SOHC VTEC Valve springs set - $179.00 : Bisimoto Engineering, Where Efficiency Meets Technological Perfection
Sprung disk, 2010+ Honda CR-Z - $130.00 : Bisimoto Engineering, Where Efficiency Meets Technological Perfection
Unsprung disk, 2010 Honda CR-Z - $130.00 : Bisimoto Engineering, Where Efficiency Meets Technological Perfection
L15, LEA1, 9:1, 74mm piston - $639.00 : Bisimoto Engineering, Where Efficiency Meets Technological Perfection
L15, L15A, L13, LEA1 Sleeving - $1,181.00 : Bisimoto Engineering, Where Efficiency Meets Technological Perfection
75mm L-series head gasket - $90.00 : Bisimoto Engineering, Where Efficiency Meets Technological Perfection
76mm L-series head gasket - $90.00 : Bisimoto Engineering, Where Efficiency Meets Technological Perfection
PORTFLOW STANDARD HONDA HEADWORK, L15A, LEA1 - $849.00 : Bisimoto Engineering, Where Efficiency Meets Technological Perfection
