Once you clone why do you care which sensor is which code? When you mount them put a label on the rim somewhere just in case.Sensors programmed easy enough. Tried the scan and clone method as well as manual code entry. I used my label maker to print off each code and stuck it to the respective new sensor. Now hopefully the batteries Don't die before this winter!
Yeah, looks like my reader is coming directly from China. My guess is that yours is too. Hopefully mine gets here soon!Good find on the wheels, hopefully the sensors mount on the steel properly. Sometimes that's an issue. The programmer I ordered came from a seller in Cali, the sensors from New York. Tracking info shows that they should be delivered today.
My ocd made me do it. Just in case they get mixed up with other sensors I have laying around.Once you clone why do you care which sensor is which code? When you mount them put a label on the rim somewhere just in case.
Some wheels don't have enough clearance for tpms sensors. Sounds like the wheels you bought were designed for the sensors so you should be fine.Yeah, looks like my reader is coming directly from China. My guess is that yours is too. Hopefully mine gets here soon!
The wheels I picked up are Honda OEM steel with TPMS. So, they should work! I hope!! Not sure what would cause them not to??
Temperature, pressure and code is all that shows up on the computer. How did you get it to display battery life?An added feature of the scan is that it will display remaining battery life - I just remembered that.
I'll have to look again... it's been 6 months at this point. I feel like it was right there with the Temp and pressure. I know I had to go online to update my software a couple times, so maybe it was there in the newest version at the time.Temperature, pressure and code is all that shows up on the computer. How did you get it to display battery life?
You mount your own tires? Haha.. sweet. Wish i could!!Finally got around to installing the sensors in the wheels. Easy enough to do. Probably easier without the tires mounted but oh well. I did drop one sensor inside the tire so I'll be fishing that one out later. Had to do something to make it exciting, process was going too smoothly.
I wasn't able to find any good steelies for the CRZ... I just got a second set of alloy rims from the classifieds here.You mount your own tires? Haha.. sweet. Wish i could!!
Gotta get mine mounted to steel wheels for winter. I still need to clone my sensors. Maybe i'll make a video at the same time.
I'll have to check in the morning after work for the software version. Off the top of my head my advice is to double check that you are in the correct menu with the correct year of CR-Z. If your batteries are strong enough to send signals to the car, I would think the scanner should be able to pick them up. Are you holding the scanner against the wheel as close to stem as you can? Or are your sensors unmounted from the wheels?Having trouble getting my reader to read the stock CRZ TPMS sensors. Any tips?
I updated the software to the latest version. What version are you running?
I need to try again when I have some more time, but, wasn't able to get it working just yet. Maybe my batteries in TPMS are low? Would suck if I couldnt get it to read at all![]()
I'm trying to scan the ones on the car, and I'm holding the scanner up close to the valve stem.I'll have to check in the morning after work for the software version. Off the top of my head my advice is to double check that you are in the correct menu with the correct year of CR-Z. If your batteries are strong enough to send signals to the car, I would think the scanner should be able to pick them up. Are you holding the scanner against the wheel as close to stem as you can? Or are your sensors unmounted from the wheels?
