1 - 4 of 4 Posts
Did anyone replace the front wheel studs? I read several threads about this on the forum here but didn't find a clear answer to the front ones:
- Can you replace the front studs without removing the bearing?
Thanks for your answers
I haven't had to replace a stud myself, but there's a notch in the splash guard which give access to pop a stud out the back of the hub without pulling the hub off.
thanks at least that's good to know that honda might designed to allow replacement without pulling - i'm awaiting delivery of my studs so going to wait if someone replies
Not a front one, but I replaced a rear one. Even though there was a notch in the splash guard, I couldn't get the new stud in. I had to do some slight cuts with a Dremel to get it to fit. Im sure it can be done on the front without removing the bearing. Removing the brake caliper and baracket also helped me.
1 - 4 of 4 Posts
