1 - 4 of 4 Posts
Hello all, I’ve search the forum and couldn’t really find a clear answer. I saw some OEM rims on an hind HRV that I think would look awesome on the car. Just not quite sure they will fit? They are 17x7.5 5 bolt 114.3 but have a 55 offset! Any help is appreciated! View attachment 64373 https://www.hubcaphaven.com/p/25521/2019-honda-hr-v-wheel-charcoal-machined-42700-t7w-ac2.html
Short answer: yes
However, the inset is pretty far. My Mugen wheels are 17x7, +48. These wheels are 17x7.5, +55. That means they sit 7mm closer to the car. Stock wheels are 16x6, +45. Unless you’re running a wider tire and/or a spacer it’s gonna look a bit weird.
Cool thanks for the reply! Would you be able to tell me what size spacers might give me a flusher look?
Your choice of tire size matters, it's not just about the wheel. That being said, this may (or may not) help:
Spoon CR93 17x8.5 +53 offset with 225/45/17. Depending on the ride height so with stock height no rubbing issues.
I made it flusher with +5mm spacers at the front and 3mm at the rear !
Thanks
Ben
Good luck!
From the wheels that I carry, my engineers do not list anything wider than 17x7.5 +50 offset as a guaranteed fitment.
1 - 4 of 4 Posts
