I've checked other threads, but haven't found anything related...
I have a 2011 CR-Z with 94K+ mile. I've not had any mechanical issues at all until a couple of weeks ago when the Air Conditioner started blasting hot-air. I took it to the dealer. They replaced the pressure switch, it worked for about 4-days and then the same issue returned. It seems if it's not that hot out it will work normally, but if it's really hot outside, it runs for about 8 to 10 minutes and then starts blasting hot-air again.
The last repair was covered by the extended warranty. According to the Honda Garage the next attempted fix would be to replace a wiring harness(?) and board to the tune of $2900 which for some reason would NOT be covered by the extended warranty.
Has anyone else had the same or similar issue with their A/C? There's no way I'm spending $2900 to repair AC on a car with 94K+ miles, especially when they aren't even sure if that will fix the issue.
