1 - 20 of 53 Posts
All depends on the wheel gap. Latest photos seem like the car is low enough. Already has a nice aggressive stance.
adjustable coil overs are the best
I imagine it will have struts like the Prius so cutting a coil out with a saw would work on that
Or if you want the Puerto Rican bouncy car you could cut the coil with a blowtorch :)
I would keep mine stock height. It's such a hassle to raise and lower it every winter here if I drive it year round. I don't like grading the snow on the roads in the winter with my front bumper.
depends on the wheel/tires size i'm thinking just enough to get just enough tuck all the way around will be very clean
I agree with BlueTwo and ArchRival; If you want it to ride smooth and handle, keep it stock.. You wanna look cool; drop it 1 to 2 inches. What's important to you?
Lowering is a bad idea. Sorry if you disagree but that's my opinion, after lowering a Civic and a WRX.
That's BS... Lowering a car isn't just for looks, and if properly aligned it will give you better handling properties versus stock height...
You will lose a bit of comfort but the handling "can" improve drastically over stock height...
If Honda comes out with the HFP suspension for the CRZ i'm jumping on that.
I installed it on my wife's Si...slight drop, no rubbing, very stiff.
Really changes the car's handling.
i'd get the HFP too but it's not low enough for me... i had Tein S-Techs on my Si 1.5" in the front 1.4" in the rear... perfect drop for the Si... no rubbing even with bigger 225 profile tires... improved handling a whole lot too...
the CR-Z i think will need more of a drop than the Si so HFP is probably out of the question for me on this one too...
IIRC I've seen parts already out in the JDM side... but then again of course.
I can't wait to get it here. I probably won't be doing lots of hardcore stuff. Maybe your basic springs, strut, and chasis parts. Also I already read that tanabe is going to be needing the car once it comes out to test those parts. According to this: Tanabe USA R&D Blog | Research & Development Session Updates Day-to-Day
So that's quick easy free parts right there.
i would drop with the HFP too... but IMO they never go low enough for me... take my Si... HFP was 0.8" or so... the springs i bought were 1.4-1.5"... not a huge difference... but way better on the looks IMO...
1 - 20 of 53 Posts
