21 - 30 of 30 Posts
I made my battle plan with the information you give me before :)
At the top, white connector between steering and cable real / at the bottom, white connector between cable real and gauge.
Need to wired cable at slot 18 17 16
64346
64347
I want to retrofit phone control witn my android head unit ( my car haven't phone bluethoot too ).
Pretty easy job, ont the steering wheel harness, there is a pink wire, it s signal for vol + / vol - / src.
You have a green wire who come from phone control, i made a bridge between this wire and the pink.
Now my android head unit got a signal from the two phone button !!!! Yes !!!
64350
Next job:
I ll try to buy a clutch and brake switchs with connectors in order to finish the job !
Today i ll cut an ECU wiring harnes to have connectors....
I ll let you know when all will work !
I got the brake sensor new for 12€ ! ( 4 pins ) 36750SJA013
64362
64363
The plan is to replace the old one by this one and re use the old one as a clutch switch, we will see....
21 - 30 of 30 Posts
