1 - 13 of 13 Posts
Does any one knows if there is a spesific cable for non navi unit to Android Universal unit my New unit is 9.7" Tesla style .when l install l cound'nt get any voice.do l have to get canbus??do we have seperate amplifier??
As it is an aftermarket ICE unit we would not be able to assist you but have you checked the install parts available from an online source that sell that ICE unit? The radios generally do not use the Canbus. They usually use the old fashioned car radio style connectors to the existing connectors that are in the car for the OEM Honda radio.
From the picture you posted it looks like you have all the connections to connect to the car that you need to wire to the radio. You need to read the directions for how to install that radio.
This is standard radio installation stuff.
If you had the base radio no sub woofer no seoarate amplified if you have an upper no navigation ( with Sub Woofer in back corner of hatch) there is a separate amplifier but if you connect into the connectors properly it will use it.
Time to read the directions for the radio you bought.
This unit is plug-and-play for the base model. You probably have an EX or higher which comes with factory amplifier which needs an Amp turn on wire which your harness does not have probably. Can you post the link for this radio?
On the 24 pin plug there is a amp turn on detect wire. Most likely the A22 Pink wire on the 24 Pin Plug if recall correctly. So connect the blue AMP turn on wire from your aftermarket radio to that plug. Either pin it to the harness or tap in to on the other side
The info below is the female side so what the stock radio input plug looks like
63648
63645
63646
63647
Thanks a lot,l have subwofer so do you know the location of the amplifier? 0r the radio Built in?
You don't need to run the cable directly to the amplifier. There is a cable on the 24 pin plug in the harness that came to the radio that you can pin or just tap in the male side of it :)
Discussion Starter · #8 ·
There is no AMP turn on Wire unfortunately but that is okay, you can use the ACC wire so Plug A wire 2 to turn the amp on since the ACC will only turn on when the car is on.
Discussion Starter · #11 ·
l couldnt able to do it myself ,thats why l went to a profesional shop. They did the job for me.
63864
1 - 13 of 13 Posts
