1 - 11 of 11 Posts
Does anyone know if these 16" wheels will fit?
Offset: 50mm
Backspacing: 6.22"
Tire size will be 215/45/16 or 225/50/16.
These are only for autoXing, no DDing.
Well, I was able to determine that AP1 S2000 front wheels do not fit without a slight bit of rubbing. The inner part of the caliper scrapes the inner hub of the wheel. Dang it, I thought I found a way to save some money.
AP1 OEM wheels:
16" x 6.5", +55 offset, 205 tire
good to know. 55 offset is too much.
im not sure what you mean by the inner part of the caliper. are you saying the "bottom part" of the caliper (closest to the hub) scrapes the hub area of the wheel?
^Yup, that's what I meant. I don't know if the offset was too much, just that the way the inner hub of the wheel was formed made it slightly touch the caliper. A tiny spacer or having the hub trimmed slightly would eliminate the problem. I just don't want to use a spacer while autoXing. I know some people do, but I don't want to put any more stress on the car than I already am.
Does anybody know the weight of this 16x6.0 CR-Z wheel? (Honda part no. 08W16-SZT-600)
It was mentioned on one of the other threads but as I remember it, its about 16.5 for the 16" wheel.
1 - 11 of 11 Posts
