Help identify OEM camera wires in radio harness - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
 1Likes
  • 1 Post By BoarX
post #1 of 5 (permalink) Old 01-30-2019, 08:32 AM Thread Starter
Damnwell_D's Avatar
Hello,
Im swapping out the factory radio with an aftermarket.
Does anyone know which wires that go into the back of the factory radio are camera wires? I have a 2016 crz the screen cracked so i did not have the option to unplug one harness clip at a time in reverse to see which one disconnects the camera.
Damnwell_D
Damnwell_D is offline
post #2 of 5 (permalink) Old 01-30-2019, 05:34 PM
Use a test light and unplug near camera and at other end and trace that way or use a meter. If screen cracked it is probably covered by Warranty. You will probably find no After market radio that will work with the lane view and rear OEM camera. Good luck though. Check out shops that have an All data subscription they may be able to print out the wiring diagram and if you buy from Crutchfield they have guides for the wiring.
post #3 of 5 (permalink) Old 04-19-2019, 12:53 AM
Send a message via Yahoo to BoarX
Sorry for a late reply, here is the link to one old post with wiring diagrams that might be relevant:
https://www.crzforum.com/forum/inter...ml#post1253153
I successfully used one for our 2014 EX, but no NAV - the wiring with for EX with NAV is quite different, but is also given in the post above.
Hope this helps someone,
Cheers,
Alex
BoarX is offline
post #4 of 5 (permalink) Old 04-19-2019, 04:54 AM
OP Never came back about this issue I guess we can presume the issue is either resolved or the OP no longer has the CR-Z. Should this topic be locked?
post #5 of 5 (permalink) Old 04-19-2019, 11:17 PM
If His Majesty is of such opinion, I do not dare to raise any objections
litz likes this.
BoarX is offline
