New Owner: Burned through 1/2 tank of gas on 2hr highway trip - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
 15Likes
post #1 of 29 (permalink) Old 09-23-2018, 03:00 PM Thread Starter
Is this normal? I filled my tank (full) right before I left. Drove in Normal on the way up, then Eco on the way back. The temperature outside wasn't too bad (about 60F). I just bought this car (2011) two days ago. Thought I could save a bit on gas, but this was just ridiculous. Any tips?
Syrah is offline
post #2 of 29 (permalink) Old 09-24-2018, 01:12 AM
qwertylesh's Avatar
The crz has a small fuel tank, it does better on consumption efficiency on long trips where theres less stop starting.
Half a tank of e10 is about $20aud for me, i get more than 2 hours out of half a tank tho unless i was driving ralley style.
You didnt get a Prius, the crz uses the ima for both efficiency and zip, so use cases differ and quite literally YMMV.
qwertylesh is online now
post #3 of 29 (permalink) Old 09-24-2018, 02:16 AM
Normal? No, not really. There could be some maintenance issues that need to be addressed(air filter, spark plugs, tire pressures). There's also a long list of other things that could be possible reasons as well, not the least is your driving style. Also, outside of the 2 hour duration we don't know any of the details of your trip. Speed, distance, weather(yes, the weather), road conditions, traffic, just for starters.
Spdbump and Zycle like this.
post #4 of 29 (permalink) Old 09-24-2018, 02:21 AM
SolidDuck's Avatar
you should be able to get 36+ MPG without even trying under any normal driving, what does your Trip computer tell you for a history?
Any Mods you know of or how long it sat on the lot?
SolidDuck is offline
post #5 of 29 (permalink) Old 09-24-2018, 08:18 PM
Welcome!
At 80 MPH (75MPH speed limit interstate) I'd get around 32 MPG. At those speeds the engine is running pretty fast and I think IVTEC is enabled hurting fuel economy. In two hours I would do 160 miles which uses about 5 gallons or about half a tank. I found there is a good amount of "reserve" gas when I drove 20-25 minutes on the highway with 0 mile range showing (I had my road bike in the back if I ran out, was small local highway) so using half a tank is not just tank capacity / 2. If you were traveling around 80 MPH then expect dramatically worse gas mileage, this happens in any car due to gearing and aerodynamics.
Tire pressure, I kept mine in the high 30 PSI. For excellent fuel economy I'd keep my speed around 60 MPH where I could get 45-50 MPG.
As posted above routine maintenance will hurt fuel economy if it is not done. Also the gas in the car might be pretty old if it sat around waiting to be sold and the owner had a replacement car already.
The CR-Z also teaches you to drive economically, listen to it, the shift indicators etc. The wonderful thing is the electric torque, I could cruise around in 6th gear city driving.
litz likes this.
Zycle is online now
post #6 of 29 (permalink) Old 09-25-2018, 10:16 AM
Econ mode kills highway mileage if there's any sort of uphill grade involved.
96firephoenix is online now
post #7 of 29 (permalink) Old 09-25-2018, 12:19 PM
Since it was your first longish trip is it possible your parking brake was dragging or you had the brake partially applied? Also replace fuel filter and any other fluids and filters, make sure tires are good for tread rotation direction (if directional) and air pressure ( I run 32 PSI in all 4) then see if MPGs improves
post #8 of 29 (permalink) Old 09-26-2018, 07:30 AM
Tire pressure makes a big difference, so doesn't tires.
I live in a hilly / mountainous area and usually only average around 28-30 mpg tops. It does better on the highway on long trips.
d1giPhux is online now
post #9 of 29 (permalink) Old 09-26-2018, 09:37 AM
Deputy Forum Librarian
supercrz's Avatar
Since this is your first post, Welcome!
I have notice if I don’t drive my CR-Z regularly it does not get great mpg. So if you bought this two days ago it could have been sitting a while. I think, once you drive it regularly the mpg will be better.
supercrz is offline
post #10 of 29 (permalink) Old 09-27-2018, 01:58 PM
rayray's Avatar
there isn't enough info given to justify a clear answer. we are trying to solve a 3 variable question with only 2 known variables.
if OP was driving an avg 100mph for 2 hrs, half a tank is actually exceptionally good (about 50mpg)
now if this 2 hrs drive was at a crawl with an avg speed under 30mph, then it would be horrendous mileage (like under 15mpg)
but generally speaking, here are some common things that can affect mileage:
- extra weight (heavy cargo, passenger, etc)
- drag (i.e. roof mounted accessories, large spoiler)
- low tire pressure
- poor wheel/tire combination (i.e. too large, too heavy, too wide, etc.)
- poor alignment
- low or bad 12V battery (while the 12V battery doesn't run the electric motor, the car will spend a lot more time charging the 12V system vs if you had a good/new battery)
- heavy use of A/C (or always on)
- behind on general engine maintenance (engine oil, air cleaner/filter, spark plugs) and use the correct oil, that is huge.
heavy stop and go traffic is also particularly hard on MPG in the CRZ due to having to start up the engine each time the car moves (no EV mode). so mileage can be very poor in gridlock traffic. even without traffic, driving at very slow speeds burns up gas as the car cannot disengage the gasoline engine except cut out fuel when braking/coasting.
'13 CRZ - PWP EX 6MT
rayray is offline
