Warnings, Electronic Parking Brakes, Fuses, oh my - Page 2 - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
 8Likes
post #11 of 22 (permalink) Old 05-29-2019, 10:50 AM
wateradept24's Avatar
Originally Posted by bwco View Post
Hi there!
The sad part is, since it's a 2016 it has the electronic parking brake which won't disengage, otherwise I could just drive it down to a shop.
Perhaps I'm missing something, but doesn't pressing the gas while in gear automatically release the brake? It does for my 2016 CVT. Is this different for the MT or does it just lock in on when something is wrong? That's mildly concerning...
Current Fleet:
2016 Honda CR-Z LX (Aegean Blue)
2007 Honda Element EX (Atomic Blue Metallic)
2005 Honda Civic Hybrid (Opal Silver Blue Metallic) - Retired, pending sale
wateradept24 is offline
post #12 of 22 (permalink) Old 05-29-2019, 11:53 PM Thread Starter
Via that site where you got the pic:
https://www.hondacarindia.com/owners...06278046-15513
Check the large fuse in the vehicle interior. If the fuse is blown, use a Phillips-head screwdriver to remove the screw and replace it with a new one.
So looks like the whole fuse just replaces. Just unscrew it and pull the whole 'multi fuse' assembly. Looks about a $30+ part.
You might have missed it at the bottom of my post, but even after removing the screw the fuse will not budge. I tried gripping and pulling it with a pliers and the plastic casing started coming apart (really, the “top” ripped off, exposing metal).
Oh well, car’s running great now..
bwco is offline
post #13 of 22 (permalink) Old 05-29-2019, 11:58 PM Thread Starter
Yes, it is supposed to do that.. but it wasn’t doing it while it was stuck in this insane “mode”.
Anyways, does this work 100% for you? I’d say 10% of the time it doesn’t automatically release the parking brake for me and I have to pull the switch, after rocking back off the brake.
bwco is offline
post #14 of 22 (permalink) Old 05-30-2019, 01:27 AM
How many miles? If you're still under 36000 or 3 years take it to the dealer.
post #15 of 22 (permalink) Old 05-30-2019, 04:07 PM
SolidDuck's Avatar
Only times I rock up on that electric brake is when I decide not to trust the door opening skills of those who pull in beside me and I already have my belt off. Seatbelt engaged is the 3rd or 4th interlock on the auto disengage.
SolidDuck is online now
post #16 of 22 (permalink) Old 05-30-2019, 08:16 PM
Been searching using the term 'multi fuse block':
So.. looks like its unscrew > lift up on tabs > pull out??
d1giPhux is offline
post #17 of 22 (permalink) Old 05-30-2019, 11:50 PM Thread Starter
Ours are a bit different.. only one screw, and I didn’t see anything about tabs. If they’re there I missed them, I will have to check in the morning.
bwco is offline
post #18 of 22 (permalink) Old 05-30-2019, 11:51 PM Thread Starter
Alas.. Just over 3 years (but very few miles).
bwco is offline
post #19 of 22 (permalink) Old 05-31-2019, 12:02 AM
Hootie's Avatar
Hmm... Odd luck but it sounds like you've gotten things figured out. What I see tends to happen is situations similar to what you're describing is that voltage DTCs begin to set when various control modules in the vehicle see a source voltage less than their minimum in order to function normally. Once said module(s) tend to see 10 volts or less, those DTCs can set and set alerts via the i-Mid display.
Sometimes a good charge via battery charger or a decent drive will allow the 12 volt battery to charge up enough and after one or more drive cycles, the DTCs will disappear.
The EPB will automatically disengage when it sees that the driver's seat belt is buckled and the vehicle begins to move via throttle input while in gear (on both CVT and M/T cars).
Slight side note: I also believe there may be a method for the EPB to engage while pulling into a parking spot nose first. I've only done it once in my 2016 M/T as well as a 2017 Civic SI but haven't quite figure out the necessary sequence to trigger it. Will have to thumb through owner's manuals and owner's preference setting guides to find that later.
Veni, vidi, velcro... I came, I saw, I stuck around.
Hootie is online now
post #20 of 22 (permalink) Old 05-31-2019, 08:41 AM
True.. i would check for the tabs though. I have a feeling that is the trick!!
d1giPhux is offline
