CR-Z Window Molding Coming up (breaking) -- Will it leak? - Page 2 - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
 4Likes
post #11 of 12 (permalink) Old 02-26-2019, 12:37 PM
Thanks for the info!!
In the FSM it says you have to pull the side trim pieces to install this. Do you? It doesn't look like you have to, but.. FSM says so.
Good to know it comes with 3m tape or whatever. I will need to wait until its nicer to pull / clean mine. Do you have any pics of your install anymore? I can host them for you if you want so you can fix your other guide.
Let me know.
You should pull the side trim pieces yes, the plastic parts, IIRC the edges of the upper trim rest underneath those. Its really easy especially considering all the other stuff you've done and again no glue or adhesive needed, they slide right off the clips, pull the clips, snap them back in once done.
Koala Yummies is offline
post #12 of 12 (permalink) Old 02-26-2019, 06:52 PM
I found it easier to leave the bottom clip in the body/pillar of each side, since that particular clip doesn't rotate 90 as easily as the other 4-5 clips in the A-pillar. So, to reinstall those trims, you're just sliding the trim piece onto that one clip and then snapping the other ones into place.
