P0420 code - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
 5Likes
post #1 of 15 (permalink) Old 04-30-2018, 02:07 PM Thread Starter
pluckedchicken's Avatar
P0420 code
Hi all,
I have a 2011 EX with 132K miles
the Systems Emission warning is on, throwing a P0420 code.
I'm not having any performance issues, misfires, or gas mileage issues....
so this means it's definitely time to replace the CAT?
If so will this work?
https://www.proimporttuners.com/part...converter.html
thanks,
Bob
pluckedchicken is offline
post #2 of 15 (permalink) Old 04-30-2018, 03:21 PM
It should work, but I don't know about that manufacturer.... I ordered a similar header, but it was a T1R, and I had to wait 3-4 months for it to arrive, check out to see if they have them in stock first. My T1R needed a few modifications to fit perfectly (had to bend EGR pipe to align with the connection, and the lower bracket that attaches to the down pipe had a third mounting/bolt hole that mounts to the engine block, and that had to be modified to fit too.) Let us know how it works out if you get it--the prices of the OEM replacement is scary!
post #3 of 15 (permalink) Old 04-30-2018, 03:41 PM Thread Starter
I almost took a dirt nap when I saw what honda wanted for a CAT.... outrageous!
I didn't want to even spend $375, unless it would fix the code. the code seemed pretty specific, but didn't know if a bad sensor would cause the same code or not...
guess I'll bit the bullet and give the MagnaFlow Header a try
Thanks!
post #4 of 15 (permalink) Old 04-30-2018, 06:19 PM
Yeah, I sold my T1R to another guy on the forum because he had to replace his cat too.... I will get another header if/when I need to replace mine in the future, but it won't sound like a Hybrid any more, LOL!
post #5 of 15 (permalink) Old 05-01-2018, 07:22 AM
I'd say it definitely means it's time to pay a shop to give you a definite cause for that code before throwing money at it blindly.
post #6 of 15 (permalink) Old 05-01-2018, 07:56 AM Thread Starter
I'm going to the Honda dealer today to program a key...
Do I ask Honda to check the O2 sensors?
post #7 of 15 (permalink) Old 05-01-2018, 09:09 AM
No, you ask them to run the appropriate diagnostic process for that code/light
post #8 of 15 (permalink) Old 05-01-2018, 11:05 AM
Well, tell them you got a P0420 DTC, but the troubleshooting starts with possibility of poor quality fuel, then ruling that out; next step to replace the cat to see if the that resolves the problem.... There are more steps to that, but basically sums it up; funny how they go quite quickly to replacing the most expensive part in troubleshooting.
Scott Plantier likes this.
post #9 of 15 (permalink) Old 05-01-2018, 01:52 PM
Litz, you have the factory manual with the troubleshooting process. I do not. My point was the code does not universally refer to a bad part. It refers to a particular process. Many think there is a 1 to 1 relationship between the code and which part to replace. There isn’t.
post #10 of 15 (permalink) Old 05-01-2018, 05:09 PM Thread Starter
The $135 diagnosis from the Honda Service dept; the front cat needs to be replaced
