PCV Valve ? - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
 3Likes
post #1 of 16 (permalink) Old 04-14-2018, 11:17 AM Thread Starter
CrzyCRZ's Avatar
PCV Valve ?
I am curious if anyone has changed their PCV valve. I found the part 17130-RTW-A01 but it doesn’t look like a conventional PCV valve compared to other cars. Do you guys change it as part of your maintenance schedule ?
CrzyCRZ is online now
post #2 of 16 (permalink) Old 04-14-2018, 01:03 PM
Originally Posted by CrzyCRZ View Post
I am curious if anyone has changed their PCV valve. I found the part 17130-RTW-A01 but it doesnít look like a conventional PCV valve compared to other cars. Do you guys change it as part of your maintenance schedule ?
Yes, that's the correct part#, but I've never had cause to replace it. I figure, it either works or it doesn't--if you idle the engine and pinch the hose, and the valve clicks, it's good. Or am I missing something? I'm good at that--missing things.
post #3 of 16 (permalink) Old 04-14-2018, 11:24 PM
do you mean part 36162-RBJ-005? purge control solenoid valve? i had mine replaced because it broke when i installed my bored throttle body lmao
andyy is offline
post #4 of 16 (permalink) Old 04-15-2018, 12:33 AM Thread Starter
CrzyCRZ's Avatar
Yes, that's the correct part#, but I've never had cause to replace it. I figure, it either works or it doesn't--if you idle the engine and pinch the hose, and the valve clicks, it's good. Or am I missing something? I'm good at that--missing things.[IMG class=inlineimg]/forum/images/CRZForum_2016/smilies/tango_face_grin.png[/IMG]
Thanks for the tip. I think I will just wait until it fails. If it ain’t break, don’t fix lol my car only has 24k miles and I am worrying too much haha
post #5 of 16 (permalink) Old 04-15-2018, 12:34 AM Thread Starter
CrzyCRZ's Avatar
Interesting, I have seen that part number but not sure where that is located. Where is it located ?
post #6 of 16 (permalink) Old 04-15-2018, 12:37 AM Thread Starter
CrzyCRZ's Avatar
Nvm, I found the part you mentioned... it’s on the throttle body. Ouch, good thing it’s not that expensive. 😄
post #7 of 16 (permalink) Old 04-15-2018, 08:30 AM
Thanks for the tip. I think I will just wait until it fails. If it ainít break, donít fix lol my car only has 24k miles and I am worrying too much haha
Yeah, it's still young at 24k, but the only things maintenance wise that I do, is to change the CVT fluid often (about 20,000 to 30,000 miles,) and the 6-Speed's trans oil at 40,000 to 50,000 miles.) I start thinking about changing the engine oil/filter when the maintenance minder reads 20% or less. I might add in there, changing coolant and brake fluid every 2-3 years. It's a Honda, so not much else to do, other than to clean it inside and out weekly and let that PWP shine!
post #8 of 16 (permalink) Old 04-15-2018, 11:16 AM
I also want to add changing the Wiper blades and both air filters annually is a good idea.
Doesn't the Minder tell you when to change CVT fluid? I changed it early with the filter you all told me about at 50K. I just had the Coolant changed at 57K.
While we are talking about Maintenance how many clicks do you have to pull up your parking brake before the car will not move? Dealer told me 5 to 8 is within specifications.
post #9 of 16 (permalink) Old 04-15-2018, 11:31 AM Thread Starter
CrzyCRZ's Avatar
I literally got the car 2 months ago. It’s a certified preowned. I decided to start the maintenance schedule myself. I changed engine oil, CVT fluid, and brake fluid. I got a little worried when my CVT got stuck in first gear starting from an auto stop up hill. I have seen a few threads that some people have the same problem. It only happened to me once and I become more gentle with the CVT now. The CVT is a lot smoother after fluid change.
Here’s what I am talking about in case anyone is interested:
https://youtu.be/uw8QSO5O7pM
post #10 of 16 (permalink) Old 04-15-2018, 11:33 AM Thread Starter
CrzyCRZ's Avatar
I am curious if the minder tells to you change the CVT fluid too. I just changed mine too.
