Group Buy: Kami Speed 2.5-Inch Race Exhaust Manifold - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
 2Likes
  • 1 Post By KamiSpeed
post #1 of 10 (permalink) Old 04-28-2019, 09:23 PM Thread Starter
MSRP: $455
Group Buy Price: $398
Tested on our resident CR-Z with positive results, so we are now moving into the group-buy phase. This is a true 2.5-inch (63.5mm outer diameter) exhaust manifold/header that was designed to work without our Test pipe. It includes the EGR Valve so that you can continued to run that system and don't have to bother blocking it off. Factory O2 sensor is also kept so your major concern will the the secondary O2 sensor throwing a code since there is no catalyzer.
We designed this for the 11-16 Honda CR-Z but it will also work with the 09-13 Honda Fit.
We will need 20 people in order to have this made and this is the GB special price (shipping within the continental USA is $8.95). Once we reach the 20 person mark the order will be put in and will take 3/4 months from that point due to the complexity of this piping design. I am also posting this on the Facebook Groups so I'll use this as the master list:
1. Jan Collazo (Deposit Pending)
2. touge_z (Deposit Pending)
3. Alex Garcia (Deposit Pending)
4. Jamie Skinner (Deposit Pending)
5. Jivi Tissaaratchi (Deposit Pending)
6. hushhushkitty (Deposit Pending)
7. Quaestor Black (ERG-less Version Deposit Pending)
8.
9.
10.
etc
Prototype model shows the mounts for the factory heat shield but the production model will not have that to reduce cost.
https://www.kamispeed.com/products/k...2013-honda-fit
ID:	50953   Click image for larger version
ID:	50955   Click image for larger version
ID:	50957   Click image for larger version
ID:	50959   Click image for larger version
KamiSpeed is offline
post #2 of 10 (permalink) Old 05-01-2019, 03:19 AM
Quaestor Black's Avatar
I'm in
Is it possible to get one without the EGR valve extension? I have the Honda EGR-less intake manifold that I can install at the same time.
Quaestor Black is offline
post #3 of 10 (permalink) Old 05-01-2019, 10:14 AM Thread Starter
Originally Posted by Quaestor Black View Post
I'm in
I'll ask the manufacturer if it's possible to make 2 different versions in the same batch, I'll let you know!
Quaestor Black likes this.
post #4 of 10 (permalink) Old 05-05-2019, 03:36 PM Thread Starter
List updated, 1/4 of the way there to get this made!
post #5 of 10 (permalink) Old 05-08-2019, 07:51 AM
so this is not to be used in conjunction with the test pipe?
morning runner is offline
post #6 of 10 (permalink) Old 05-08-2019, 12:45 PM Thread Starter
This is ideally used with our test pipe, they were designed together. We are just noting that it'll require a tune or O2 extension to work without a check engine light
post #7 of 10 (permalink) Old 05-16-2019, 01:38 AM
Any news on if the header is available without the EGR extension?
post #8 of 10 (permalink) Old 05-21-2019, 04:15 PM Thread Starter
So they finally got back to me, they can 100% do it, but they're going to charge the same price if we want it in the same batch. I would do another batch but I need to order at least 30 of each version, so unfortunately it'll have to be at this price. Let me know if you want in!
post #9 of 10 (permalink) Old 05-22-2019, 02:08 AM
That's good news! The price isn't a problem, so it can be part of this batch. Sign me up for one
post #10 of 10 (permalink) Old 05-22-2019, 09:28 AM Thread Starter
Will do, thank you!
