CR-Z Wheel Fitment Thread - Page 3 - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
 1Likes
post #21 of 1426 (permalink) Old 03-25-2011, 02:26 AM
only9balls's Avatar
Originally Posted by Scotty001 View Post
^ the best fit and look I have seen. Very well selected.
Thanks Scotty! It does get a lot of looks on the road now, my son is 13 and thought it was so cool when we drove through a gas station parking lot and everyone was checking out the car and pointing. I have tint on it now and I think it looks even better... too bad I couldn't get pics with that on, it's been raining nonstop here
Anyhoo, not to hijack the thread, but thank you for the kind words!
only9balls is offline
post #22 of 1426 (permalink) Old 03-25-2011, 05:59 AM
TCroly's Avatar
Originally Posted by only9balls View Post
Wheels: Tenzo R Sport DC-5 Version 2 : 18x8" : +45 Offset : Matte Black/Machined Lip and Center : 21.7 lbs
Tires: Yokohama S Drive : 225/35/18 : 22 lbs : Treadwear 300
Suspension: TEIN SS Coilovers : Drop 1.25"
If you have no rubbing problems, then this looks like about as good as you can get for a drop and big wheel/tire set-up. Well done!
I found this website that helps you analyze proposed wheel and tire combinations:
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
TCroly is offline
post #23 of 1426 (permalink) Old 03-25-2011, 01:06 PM
only9balls's Avatar
Thanks Tom! They don't rub, but I think they are about as close as you can get in the front.
post #24 of 1426 (permalink) Old 03-25-2011, 01:21 PM
only9balls's Avatar
Cool app... Here is what it shows for my application:
post #25 of 1426 (permalink) Old 03-25-2011, 06:09 PM
Very nice, does anyone know if the white cr-z is deeper and how much?
here is mine with 9x18 ET 35 and 225/35 in the back......
Max500 is offline
post #26 of 1426 (permalink) Old 03-25-2011, 07:28 PM
only9balls's Avatar
Hi Max,
Are you saying that yours rub in the back? All the CRZ's use the same sheet metal regardless of color. If I read this corredtly, you are tunning 18x9" wheels with a 35 offset... Those wheels are a full inch wider than mine and offest 10mm more to the ouside, so they would stick out almost 1,5" farther than mine do, and I am pretty sure those would rub on my car too,
post #27 of 1426 (permalink) Old 03-25-2011, 08:38 PM Thread Starter
roddy's Avatar
besides diameter, i'm running close to that size in the rear, but on different suspension.
max looks like you're running stock height? more info please. more pictures too.
need an avatar? take one from my flickr
have questiosn? fb me: www.facebook.com/roddy3
roddy is offline
post #28 of 1426 (permalink) Old 03-26-2011, 12:46 AM
hoisumguo's Avatar
Sorry it took so long Roddy, needed to wait until I got on my computer on the weekend.
Initial tire set
Wheel info:
Brand: Wedsport SA-55m Gunmetal
Diameter: 18
Width: 8
offset: +45
Face: FF
Hub Bore: 73
Weight: 18.5 lbs
Tire info:
Brand/Model: Continental DWS
Suspension info:
Cusco Zero One, default 1.7" drop front/back.
Changed out to:
Tire info:
Brand/Model: Falken 912
Had 20mm spacers on back for a while, but didn't like the rub during large dips or bumps so have recently removed them. Continuing to lower again without spacers, but haven't found the correct height yet.
NOTE:
Rubbing in the rear seems to be primarily due to the rear fender securing screw mount at the top of the wheel well. This is problematic even when/if trying to roll them as the large piece of plastic holding the rear bumper will need to be pushed out quite a bit or ground down which is not ideal. This does not exist in the front fender well and should not be an issue if front rolling is necessary.
-Hoi
hoisumguo is offline
post #29 of 1426 (permalink) Old 03-26-2011, 09:36 AM
TinTin's Avatar
Hoi, i ran a 235 and felt some rubbing when going over bumps at fukk lock. The rubbing was at the front fender liner at about the 2o clock position drivers side theres a boxy chunk that comes out. I think it was that. Do you have any issues?
Its a BRZ now.
TinTin is offline
post #30 of 1426 (permalink) Old 03-29-2011, 04:17 PM
Ludercrz's Avatar
updated my post on Page 2 with Pics. finally got them installed.
Ludercrz is offline
