F'ing IMA - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 12-16-2011, 11:36 PM   #1 (permalink)
nCftm's Avatar
Thumbs down F'ing IMA
base model 6mt
so my car rolled back a few inches from its parked position bc its on flat land i didnt place the e-brake on. i got into my car a few hours later and placed my foot on the clutch and the brake to start it. suddenly i feel a thrust and notice the vehicle moving forward and jumping the curb in front of me. mind you my foot is on the brakes already. I instantly pull the e-brake and turn off the car to stop it from hitting the apt in front of me. I already had the recall upgrade. so what the f?
nCftm is offline   Reply With Quote
Old 12-16-2011, 11:45 PM   #2 (permalink)
Tbot's Avatar
Lawsuit!!! Just give me some of the sum please.
Old 12-16-2011, 11:49 PM   #3 (permalink)
nCftm's Avatar
lol i already calling honda. well attempted to call corporate but they are closed so i call the dealer. they want me to get it towed to them to look at the car but want me to pay for the tow. I got the service managers number but she wont be in till tomorrow.
Old 12-17-2011, 12:34 AM   #4 (permalink)
sneak1413's Avatar
Not sure how a 120 some ft-lbs of torque in the car can trust the car forward like you claim when you pressin the brakes and have the clutch dissengaged? I have tried to take off with the parking brake on(only the back 2 tires) and it did not go hardly anywhere. Your clutch must be broken and fully engaged and the throttle stuck wide open or something. Even then im not sure how all that could have overcome the brakes. I guess what i am saying is i am confused here...
sneak1413 is offline   Reply With Quote
Old 12-17-2011, 12:41 AM   #5 (permalink)
Old 12-17-2011, 12:41 AM   #6 (permalink)
Debello's Avatar
If the clutch was in, then there is no way for the IMA to transfer power to the wheels. Are you sure you didn't pop the clutch with the car in a forward gear.
Debello is offline   Reply With Quote
Old 12-17-2011, 01:15 AM   #7 (permalink)
nCftm's Avatar
Why else would i be telling you all if i knew the answer.. im not trolling or lieing im presenting the fact as they are... if the car can engage in reverse while stopped and in gear. im sure it possible it can do moving forward.
Old 12-17-2011, 05:46 AM   #8 (permalink)
sohcsol's Avatar
No need to get defensive, were all interested to know the facts and why or how this happened... It just seems like somethings missing, maybe something you hadnt realized at the time. The cars brakes and clutch are both mechanical, and Im guessing still fairly new. Without failure of one or both of those components, what you experienced does seem unlikely.
The reverse lurch happens when engaged in first gear, releasing the clutch quickly after the car re-starts usually from autostop when the IMA battery is low. It makes sense, because there is nothing mechanical controlling the direction of the electric motor, so from a standstill it can go either direction. Understanding how it happens, I dont see how they couldve fixed the problem with a simple ecu reflash, but Ive tried and cannot get mine to do it...
2011 CR-Z EX, 6MT, CBP, #7960
Old 12-17-2011, 06:19 AM   #9 (permalink)
It's when the gas engine stalls, i.e. not stopped in a controlled manner - I suspect the IMA ECU just loses track of where the motor is (rotational position). The motor isn't a simple on/off, it has multiple field coils that need to be energised in the correct order, and if you're unlucky it will happen to fire up the wrong way.
I'd guess the ECU flash incorporates new/different position information to prevent this.
OP - As others have said, if the clutch is disengaged, there is no drive to the wheels.
If you're positive the pedal was down then it looks like a clutch failure of some kind.
ETA - No matter how flat the ground, I would never leave my car without the handbrake (e-brake) engaged or in gear.
2010 CR-Z GT 6MT
Crystal Black Pearl
lexicon is online now   Reply With Quote
Old 12-17-2011, 09:13 AM   #10 (permalink)
gordonfc's Avatar
In Canada, New Brunswick province, we have a stretch of road refered to as
'Magnetic Hill'. People come from all over to park their car, turn off the engine and watch the car go 'uphill'.
It is a natural optical illusion, caused by the surrounding landscape and terrain but confuses many people.
Is it possible that your CRZ was NOT parked on the level and simply rolled ?
