Recall: 2011 Honda CR-Z, 6 speed manual - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
post #1 of 204 (permalink) Old 09-04-2011, 12:42 AM Thread Starter
DerekS's Avatar
Post Recall: 2011 Honda CR-Z, 6 speed manual
Fortunately just a software update, but it looks important.
Additionally, Honda will voluntarily recall 5,626 CR-Z vehicles from the 2011 model year in the U.S. that are equipped with manual transmissions to update the software that controls the hybrid electric motor. In the affected vehicles, when the gasoline engine has stalled with the IMA battery in a very low state of charge and the transmission in gear, it is possible for the electric motor to rotate in the direction opposite to that selected by the transmission. If this occurs and the driver has not engaged the brakes, the vehicle may slowly roll in an unexpected direction (e.g., backwards when the transmission is in a forward gear), potentially leading to a crash. A software update will add further controls to correct the problem. No injuries or deaths have been reported related to this condition.
Statement by American Honda Regarding Two Recalls: 2006 Honda CR-V; 2011 Honda CR-Z with Manual Transmission - Honda.com
Granny shiftin' not double clutchin' like you should. You're lucky that hundred shot of NOS didn't blow the welds on the intake!
Last edited by DerekS; 09-04-2011 at 10:27 AM. Reason: Adding description of the problem from the slow source link.
DerekS is offline
post #2 of 204 (permalink) Old 09-04-2011, 12:48 AM
Ludercrz's Avatar
wonder if Canada is affected too. can't check on the Honda website until the end of September is what that article says.
Ludercrz is offline
post #3 of 204 (permalink) Old 09-04-2011, 12:56 AM Thread Starter
DerekS's Avatar
Sounds like all the 6mts made, to me.
DerekS is offline
post #4 of 204 (permalink) Old 09-04-2011, 01:04 AM
Ludercrz's Avatar
hopefully it ends up giving more power lol
Ludercrz is offline
post #5 of 204 (permalink) Old 09-04-2011, 01:11 AM
TCroly's Avatar
The symptoms of this malfunction described in the recall seem very similar to that which was described by a new owner whose wife was trying out the hill holder clutch upon driving the car home from the dealer and suggested that car accelerated in reverse while she tried to disengage the clutch.
At the time, the consensus on this forum was that the car simply rolling down hill from gravity might have felt like it was accelerating in reverse, but the strange description of this malfunction suggests that just such a thing could have been initiated by the car.
TCroly is offline
post #6 of 204 (permalink) Old 09-04-2011, 03:14 AM
andrewr's Avatar
Your link seems to be dead? Found another one:
Not good. My battery never goes under half but... I like the way it runs now and I dont like changes much. I dont like it driving the wrong way either tho. Would it then be spinning the gas motor backwards too? How is that possible?
andrewr is offline
post #7 of 204 (permalink) Old 09-04-2011, 03:55 AM
Derek's link still works for me.
The IMA motor is attached to the gas motor so yes, it would go backwards too.
The text says this happens when the gas engine has stalled, so it's not running under it's own power and it could rotate backwards just as easily as forwards.
Unrelated, but one of my cars years ago would "run on" after turning the ignition off, not unusual in the days before electronic injection, but that would sometimes go backwards.
2010 CR-Z GT 6MT
Crystal Black Pearl
lexicon is offline
post #8 of 204 (permalink) Old 09-04-2011, 08:19 AM
Varmint's Avatar
Thanks Derek. Good to know.
Varmint is offline
post #9 of 204 (permalink) Old 09-04-2011, 08:56 AM
Thanks for posting this!
hotboxn is offline
post #10 of 204 (permalink) Old 09-04-2011, 09:52 AM
TotallyCRZ's Avatar
Yikes! Good thing I got the CVT instead yesterday
Thanks for the info!
TotallyCRZ is offline
