Auto Stop - Engine Restart at Higher Speeds? - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 05-26-2011, 02:57 PM   #1 (permalink)
EmptieHand's Avatar
Default Auto Stop - Engine Restart at Higher Speeds?
So, I've been trying to take advantage of auto stop as much as I can by lightly pushing the brake so that I can engage auto stop without slowing down the car.
Today though, I was on a mild downhill grade while in auto stop, and hit 9-10mph before I let go of the brake. The engine kicked in with a mild lurch. It definitely wasn't as smooth as when I cancel auto stop from 0-6mph.
Anyhow, you guys think it would be better if I'm going downhill in autostop... to brake until I get to the 0-6mph range before letting the engine restart again? Iono... common sense tells me I should reduce the speed before restarting the engine.
(Wish I knew enough about cars and engines to answer these questions myself... but thanks for all your patience. )
PWP CR-Z EX CVT
EmptieHand is offline   Reply With Quote
Old 12-11-2011, 07:37 PM   #2 (permalink)
Thumbs up
Mine never starts back rough when I do that. There is a hill on my way to work that you have to slow way down before turning, so I slow down to less than 20 to get Auto-Stop to shut it down, then just barely press enough on the brake to keep it stopped while going down the hill. Sometimes I reach 50+ MPH before I start it back, it is smooth every time.
2011 CR-Z, Black, 6MT
1991 CRX HF, Blue, 5MT
IsaacMTSU is offline   Reply With Quote
Old 12-11-2011, 08:22 PM   #3 (permalink)
Old 12-12-2011, 04:31 PM   #4 (permalink)
kmanatt's Avatar
Don't know about that, mine always re-starts at about 19mph even with a light foot on the brake. I guess it does this to assure that I have vacuum for the power brakes. K
(MT6 here)
Bugz
Old 12-14-2011, 11:40 PM   #5 (permalink)
Saibot's Avatar
perhaps its because your driving a CVT? the clutch re-engages at a different speed than the wheels...
maybe autostop in neutral is better? (actually idk how auto stop works in cvt if it would even work when ur in neutral gear).. but that may be your solution.
Saibot is offline   Reply With Quote
Old 12-22-2011, 11:55 AM   #6 (permalink)
Maybe...ours is a MT
Old 12-23-2011, 10:27 PM   #7 (permalink)
Jwarian's Avatar
I have gotten above 50 down a hill with auto stop, you must have it in neutral with te brake triggered, and not depressing the clutch
Jwarian is offline   Reply With Quote
