4-5 Shift Difficult - Weak Reverse Spring? - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 03-17-2011, 10:06 PM   #1 (permalink)
Default 4-5 Shift Difficult - Weak Reverse Spring?
I'm contemplating a 6-speed CR-Z and I have a question about the shifter. The spring in the shifter that keeps you out of the reverse gate seems REALLY weak in this car. Meaning, shifting from 4th to 5th requires very light pressure or you end up in a dead end.
I assume it's common and was wondering if there is an improved shifter out there yet that makes the reverse gate harder to enter.
jmatero is offline   Reply With Quote
Old 03-19-2011, 08:36 AM   #2 (permalink)
stonetyke's Avatar
Had the CR-Zed (6MT in UK) since July 10, never had any issues with going into reverse accidently, the gear box on this car is superb, one of the slickest I've ever had.
Why try to change something that does the job!!
stonetyke is offline   Reply With Quote
Old 03-19-2011, 05:19 PM   #3 (permalink)
fireballer44's Avatar
The shifter locks out reverse once you're moving forward, you can't move the shifter further to the right than the 5th and 6th gear gates. I've never had a problem at all with even coming close to shifting into reverse accidentally.
My 91 Accord had a similar setup, being a 5-speed it's reverse gear was where 6th gear is in the CRZ, but you couldn't shift into it accidentally when going from 5th to 4th, etc.
fireballer44 is offline   Reply With Quote
Old 03-20-2011, 01:14 AM   #4 (permalink)
Ah gotcha... haven't driven it yet but running through the gears in a stopped car, there was no defined 5/6 gate. So the R gate way off to the right is blocked when the car is in motion... that makes sense now! Thanks!
