upgrading speakers .. what should i get? - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
 2Likes
  • 1 Post By d1giPhux
  • 1 Post By prospect
post #1 of 7 (permalink) Old 01-06-2017, 07:00 PM Thread Starter
Looking to upgrade my front, and rear speakers. Don't want to mess around with any custom BS at all. Just want to replace and enjoy!
What do you all reccomend? What have you installed in your car? How does it sound compared to the 'premium honda audio package' that I have in my 2011 (or your car)?
Really just want to pull the speakers, install new ones, and enjoy. I don't want to mess around with much custom stuff. I can install spacers, solder, etc. Just don't really want to run into any trouble.
Shoot some suggestions at me! What have you found that you love so far!?!
d1giPhux is offline
post #2 of 7 (permalink) Old 01-07-2017, 11:54 PM
having done this, there really is no need to obsess over what to get. the only things to change are the main speakers. the tweeters and sub are pretty good quality (although read the thread about stuffing the sub box - this is an audible difference)
the main speakers are truly horrible, i have no idea how they even work with a magnet that small! i bought some generic speakers for the local motor parts place, about 60 for four, night and day difference.
youll need some spacers (or make your own from MDF), some self drilling sheet metal screws, and some spade connectors too.
prospect is online now
post #3 of 7 (permalink) Old 01-10-2017, 09:01 PM Thread Starter
Awesome! Thanks for the heads up. And here i thought the stock speakers sounded good!! LOL. Shows how much I know.
Looks like these will fit the car decently, and come with some spacers:
https://www.crutchfield.com/p_107DB6...er-reviews-tab
A bit expensive, but not TOO bad. Wish i could buy JUST the speakers though. Says the tweeters will fit too, but mine are working fine it seems.
litz likes this.
d1giPhux is offline
post #4 of 7 (permalink) Old 01-11-2017, 06:17 PM
looks good!
yeah i wouldn't bother with the tweeters, the originals blend in nicely and the magnet is pretty big (bigger than the ones that came with my speakers anyway)
i would advise making your own spacers if you can though - from memory you need bigger ones on the rear, i made mine from 1 sheet of 16mm mdf and one sheet of 5mm, stacking to make thicker ones.
i also put components in the front (better bass) and coaxials in the rear ( no tweeters back there) although youll find when you test them that the rears dont put out much volume, something to do with the sound balancing, not a fault!
post #5 of 7 (permalink) Old 01-12-2017, 08:57 PM Thread Starter
So the spacers that come with these kits wont really work? Hmm..
How did you go about making a spacer? I could probably make some, but, sounds like a bit of a pain.
Also, the rear speakers stock are coaxial right? I wonder why the balance would be off then? Good to know though! Thanks!
d1giPhux is offline
post #6 of 7 (permalink) Old 01-13-2017, 07:04 PM
heh "coaxial" you havnt seen the originals yet!
not that the supplied spacers wont work, but from what i recall i had to pack out the rears quite a bit as they are mounted quite close to the outer skin of the car, the fronts not so much. so its more to save the hassle of swapping them / bodging the job
all you need for spacers is mdf, the paper template that all the speakers i have ever bought come with, a pen, jigsaw cutter, and a drill of some sort to make the inital hole for the saw.
then again, if youre not confident with / dont have the tools to do the job, spacers may well be easier for you!
as for how to actually do the job, i used the frankly excellent guide in the DIY section of the forum.
sub box mod
DIY: OEM EX Sub
speaker replacement
DIY: EX Model 7 Speaker Polk upgrade
d1giPhux likes this.
post #7 of 7 (permalink) Old 01-15-2017, 04:22 PM Thread Starter
Nice! Thanks!!
I can definitely make the spacers, I just don't want to. LOL. I guess I will though.
Also, I might just use a plastic cutting board or something to make some plastic ones. Might be cheaper than MDF. Same thing people use to make suspension spacers as well.
So are you saying that when you put new rear speakers in the cone is much bigger and therefore much closer to the plastic on the car?
Thanks again for all the help and suggestions!
What type of stuff you have in your car?
d1giPhux is offline
