Steering wheel control - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 09-16-2012, 11:56 PM   #1 (permalink)
Default Steering wheel control
Hi Guys,
Can someone help me with the steering wheel control. I tried to connect the wires as said on the axxess web and it dont seem to work. Not sure what I am doing wrong. I connected the grey and red wire to the pink wire on the harness and took the white wire of the harness and grounded the wire. The unit stays on red but nothing happens when I press the buttons. Can someone tell me what I am doing wrong.
Thanks
noob is offline   Reply With Quote
Old 09-17-2012, 07:09 AM   #2 (permalink)
Stefcrz's Avatar
A1 BLK MAIN GND Ground for audio unit (G503)
A2 WHT ILLUMI-(BULB) Detects illumination control signal
A3 PNK -B BACK UP Continuous power source
A4 RED ILLUMI- Inputs parking light on signal
A5 RED RL PRE- Outputs sound signal for left rear speaker
A6 GRN RL PRE- Outputs sound signal for left rear speaker
A7 Not used Not used ―――
A8 Not used Not used ―――
A9 LT GRN RR PRE- Outputs sound signal for right rear speaker
A10 WHT RR PRE- Outputs sound signal for right rear speaker
A11 WHT REMOTE GND Ground for audio remote switch
A12 GRN SCTY Security signal from Multiplex integrated control unit (MICU)
A13 BLU K-LINE Detects scan tool signal (serial data)
A14 Not used Not used ―――
A15 YEL FL PRE- Outputs sound signal for driver's door speaker and left tweeter
A16 PNK FL PRE- Outputs sound signal for driver's door speaker and left tweeter
A17 Not used Not used ―――
A18 Not used Not used ―――
A19 GRN FR PRE- Outputs sound signal for passenger's door speaker and right tweeter
A20 ORN FR PRE- Outputs sound signal for passenger's door speaker and right tweeter
A21 WHT SWD-B Outputs voltage for stereo amplifier switching ON/OFF
A22 PNK REMOTE SW Detects voltage for audio remote switch
A23 BLU VSP Inputs vehicle speed pulse from ECM/PCM
A24 PUR ACC Power source for accessories
For the Steering wheel controls the wire you need are the marked above. From the head unit harness the A11 white for ground and A22 pink for data.
Stefcrz is online now   Reply With Quote
Old 09-17-2012, 07:22 PM   #3 (permalink)
Thanks man
I got those wires connected. Like said on the list you have there. I just got off the phone with Tech support at Axxess and they told me that thge Clarion NX702 has a diff power signiture or something and says that I need to do additional programing which is Volume button 20 sec and up button 3 times 3 sec and 1 down 3 sec. What a hassel that they dont put that info on the web.
I also tried the bluetooth wire someone posted a while ago about a green wire from the HFL control unit to be connected with the white and green wire from the ASWC and that is a no go. Later on I will be getting rid of this Clarion NX702 and will be getting a Pioneer AVIC 140bh and then I will try the mic to see that part works or not. Thanks again Stefcrz really appriciated your help
Old 09-29-2012, 10:28 AM   #4 (permalink)
YLA
YLA's Avatar
First time I see "Axxess", seems to be a fine solutions.. are you happy with it "noob"?
info for others: Axxess Interface - Steering Wheel Control
pdf: http://www.axxessinterface.com/docs/...2_BROCHURE.pdf
http://promo-code.be (sorry, only in Dutch or French)
YLA is offline   Reply With Quote
Old 09-30-2012, 01:02 AM   #5 (permalink)
Steering control seem to be ok. Not too bad
