#121 (permalink) |
#122 (permalink) |
What also works is rest the left side of your head aginst the left door glass and adjust the left mirror to see correctly. Then lean your head to the right about the same angle and then adjust your right mirror accordingly USA only.
#123 (permalink) |
To see out of that little right side triangle window incline your passenger seat back.
The upright Pass. seat headrest blocks the view out of that window. I/ 5' 8" (172cm) in shoes. Would be different if you are shorter or taller. Also rotating your inside mirror 180 degrees raises the mirror ~ 1 1/2". Due to the pivot point NOT being 1/2 way up the mirror but ~1/2" above it. Just turn the mirror upside down, you do NOT have to remove it. I also use cover mirrors in and out. Works. |
#125 (permalink) |
I almost took a motorcyclist out last week...which kinda sucks cause I myself own a motorcycle.
The thing is I do check my blind spots with every lane change....be predictable people. I realize there's an urge to give your motorcycle a handful of throttle, but if you're where I didn't see you a second ago, I might end up in your path! |
