low tire pressure warning light - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 10-28-2012, 10:42 PM   #1 (permalink)
Default low tire pressure warning light
My tire pressure warning light is coming on every couple of months. Had the care in twice and the air pressure was fine. Anyone have a similar situation and how was it resolved?
ziller is offline   Reply With Quote
Old 10-30-2012, 02:46 AM   #2 (permalink)
Fixed it on mine by taking it to the dealer, they took a nail out of it.
The local tyre centre couldn't find the nail.
JoeJoe is offline   Reply With Quote
Old 10-31-2012, 03:34 PM   #3 (permalink)
Yeah mine keeps coming on every few months also. I just add air and drive it a bit and it goes off, but it never fails to come back on. Its never the same tire either. I always just assumed the TPMS was sensitive.
crzRI is offline   Reply With Quote
Old 10-31-2012, 04:15 PM   #4 (permalink)
People really should be checking COLD tire pressure with a guage at every other gas fill-up.
Colder weather means a decrease of tire pressure. Summer heat causes pressure to build higher, and now the opposite.
bheinen74 is offline   Reply With Quote
Old 10-31-2012, 04:29 PM   #5 (permalink)
BANNED
OneFitZ's Avatar
Temp changes could cause that. If you think there is a leak, take the tire off and put soapy water on it, rotate, and look for bubbles.
Old 10-31-2012, 11:26 PM   #6 (permalink)
Had it at the dealer today and they put in 34 lbs. Feels like a rock.
Old 11-03-2012, 11:04 AM   #7 (permalink)
Black Hive's Avatar
Mine goes off a lot, usually different tires. I think it's more sensitive than any other I've owned, but it does a great job. When it comes on, I always check all the tires and fill up as needed, then it turns off. However, I often think there is a flat at first because I've had a lot of issues with these tires.
Black Hive is offline   Reply With Quote
Old 11-03-2012, 02:52 PM   #8 (permalink)
LeeMoon's Avatar
When the weather turns colder I've had the TPMS low pressure light come on. I've always run it to the dealer on the way to work and they take care of it right away.
We had our first cool temps earlier this week and the CR-Z TPMS low pressure light didn't come on. It did turn on with my 2010 Insight. Today I finally got around to checking the cold tire pressure (they were all around 29-30 PSI), so I inflated them all to 33 (as indicated on the car). Drove it down the street and back and the warning light turned off. Took the Insight to Target and back and the warning is definitely cleared.
LeeMoon is online now   Reply With Quote
