US 101, Camarillo Grade, Test Run - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 11-28-2011, 03:00 PM   #1 (permalink)
gozoner's Avatar
Default US 101, Camarillo Grade, Test Run
Anybody with a CVT in T.O., Camarillo, or Oxnard who cares to perform a test run up the Camarillo grade? In 'econ mode' with cruise control set to '65 mph' and the IMA at about 7 bars at the base of the hill, what RPMs does the engine select when heading up the hill?
gozoner is online now   Reply With Quote
Old 11-28-2011, 03:59 PM   #2 (permalink)
Willard's Avatar
I've done that run many times, but with the 6MT.
Willard is offline   Reply With Quote
Old 11-28-2011, 05:43 PM   #3 (permalink)
What are you really looking to find out here What's the percentage of the grade
2011 SSM CR-Z EX/6MT
Old 11-28-2011, 06:17 PM   #4 (permalink)
I used to live in Topanga Canyon and worked at Pt Mugu, so I know that road, and I'm guessing he wants to know if it can hold its speed and maker up the hill without problems.
Momentum, Momentum Performance
Mike is offline   Reply With Quote
Old 11-28-2011, 06:25 PM   #5 (permalink)
gozoner's Avatar
I'm looking to learn what RPMs the engine controller chooses when in 'econ mode'. I'm figuring the engine will chose the RPMs for highest efficiency while still pulling the long, steep hill. I have a 6MT (so the engine doesn't optimize the RPMs, I chose the RPMs).
Old 11-29-2011, 01:51 PM   #6 (permalink)
gozoner's Avatar
I do that run every two week days, from SB to Pasadena. I hit the hill at 50 miles on the trip meter and ~41 mpg. At the top of the hill I'm at ~38.5 - lost 2.5 mpg. I spend the remaining 50 miles getting back up to ~41 mpg.
Without a CVT test run, I'm going to experiment with gear/mode combinations to see what gets the best MPG. I'm going to reset the B trip meter at Camarillo Springs and then read the MPG at the crest. 6th gear, 65 mph will not hold the hill so I'll try 4th and 5th gears in econ, normal and sport over then next couple of weeks.
Old 11-30-2011, 01:14 AM   #7 (permalink)
I haven't personally set cruise to climb huge hills or mountain roads but just hitting a medium to small hills. I notice having cruise set on 6 gear(6spd tranny) it does not auto down shift to compensate for torque or power and it shot up accelerator and IMA assist in cruise mode. I suppose that's how manuals are manual even in cruise mode. Maybe CVTs will auto downshift for the proper power band to maintain a constant speed in cruise control mode with relatively low loss to fuel economy compare to manual.
MaxMp is offline   Reply With Quote
Old 11-30-2011, 01:26 AM   #8 (permalink)
Yes, for a CVT is totally drive by wire in Cruise.. In ECON, you do lose 1-4 MPH going up a hill and can gain 1-4 going down so if in traffic, can be annoying. It is trying to get the best MPG. In Normal - 1-2 either way. In Sport, does a good job of keeping it at set speed.
Old 11-30-2011, 09:34 AM   #9 (permalink)
gozoner's Avatar
Exactly. And my question is 'what RPMs does the engine choose?'
Old 12-21-2011, 01:43 AM   #10 (permalink)
josbo001's Avatar
Argh. I misunderstood your question. Thought you wanted gears. Anyway, I tried it CVT up the Camarillo grade in cruise control ECON and it kept fluctuating between 5 and 6 gear. Killed my MPG. And was slow as hell!!
Going to make that run again on Xmas, so this time I will pay attention to RPMs/battery level and get back to you.
josbo001 is offline   Reply With Quote
