ECON vs SPORT.....surprise inside! - Page 32 - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 09-23-2012, 10:48 PM   #311 (permalink)
Originally Posted by Klasse Act View Post
Surprised you didn't run premium from the git go, LOL!
I would have but I did not have the ultra gauge last car when new and I wanted to see what the car was doing. This car has a i Mid display with Econ too. I filled up with Shell V power and the motor runs better with better power. The 3 numbers I was concern with did not change that much though. I think the ecu is locked until motor is broken in.
The ultra gauge is off by 20 percent on its mpg and still wont show a full tank. I did check the settings and its right. If I use the max percent at fill up it is accurate at fill up but with a 20 percent less than what the average mpg is. It says I am getting 55 mpg.
I would have used Shell regular but no power and being on the highway most of the time you need a safety margin encase of emergency which premium gives me. MPG will be secondary and will try BP ultimate if their prices come down. Wish the temperatures did not fall so fast, we are 15 degrees below normal so I hope its not a sign of a bad winter.
Old 09-24-2012, 10:05 AM   #312 (permalink)
ffearless's Avatar
You can calibrate the mpg, tank capacity, low and high thresholds for fill ups and the ultra gauge will give quite accurate info.
2011 CR-Z EX 6mt w/Nav - Milano Red
ffearless is offline   Reply With Quote
Old 09-24-2012, 10:16 PM   #313 (permalink)
Thank you, I will retry to set it again next fill up. Whats weird is I did the high threshold. I wonder if that is why my fuel trims are higher too? It is accurate when you use the correction features. Honda does make some good cars that get great mpg.
KA, its warming up and the range went up to almost 600 miles today. Premium does help get better mpg and has a lot more power for the interstate. This is the first time using Shell for more than 1 tank and having the ultra gauge and seeing the numbers are really enlightening. So far this is what I have observed. Shell regular is better than what the dealer uses and Shell plus is not that much better than regular with only a little more power and mpg about the same. Premium with 10 miles city and lots of idling and 23 mpg on the display I got it to 41mpg today and driving only to and from work driving 65 mph. I did not think I was going to get the mpg back especially that fast. The car is in Econ too.
Old 09-25-2012, 09:07 AM   #314 (permalink)
Klasse Act's Avatar
The gas prices are trying to come down a bit, so that's good and I see BP is a little lower at a couple of the stations I pass but I'm sticking with Shell 93. While I'm on my trip down to the Dragon I'm not going to have the luxury of Shell everytime but I'll be using brand name fuels though, that's for sure and I know where we're staying there's a Shell station, so that's good and there's another one on the other side of the mountain 65 miles away.
I'm really going to be interested in the mileage on the freeway this time as the best I got last year was 44.6 mpg from northern KY to Chicago and that was the car in stock trim w/ just a drop-in K&N, that's it. 16 more days to go for that!
2011 CR-Z EX 6MT/SSM/K&N typhoon/"mufflerless" exhaust
17" MB Weapons/225-45 Conti DWS/lots of "little" mods
Paint surface protection count...(83-37)
Klasse Act is offline   Reply With Quote
Old 09-26-2012, 08:52 AM   #315 (permalink)
Klasse Act's Avatar
The cooler weather has affected my MPG's, down to 40.7 mpg's on the last tank, got gas fuel this morning and I was pretty surprised! I know there were a couple days leading up to this fill-up where my outside temp was showing upper 40's and temps going to work were in the low to mid 60's. I'm still using Shell 93 but have gotten it from a different station, today I went back to the one I usually go to. My OBC showed 42.4 mpg and its never been this big of gap, hmmmm
Old 09-26-2012, 09:40 PM   #316 (permalink)
The ultra gauge is showing high barometric pressures and that lowers mpg in my opinion. Cooler mornings and high barometric uses more fuel. I see my OBC going down from 43 to 41 and the range drops 60 miles. I get most of it back on the highway. Running premium 60/40 mix with mid grade. I see its a lot easier to get better mpg and I am seeing higher mpg at cruise but goes down quicker during warm up. Honda seems to have the ecu locked and seeing signs of advanced timing and the fuel trims are now both 6 instead of 10 short term and 8 long term. That is in ECON. Next tank I will turn it off.
Old 09-27-2012, 08:24 AM   #317 (permalink)
Klasse Act's Avatar
I will never use ECON, it just brings my mileage down. I've tried twice and it just doesn't work and I'm driving the car normal too, no lead foot, its a CR-Z after all, LOL!
Looking forward to seeing your numbers Glenn.
Old 09-27-2012, 08:43 AM   #318 (permalink)
I drive 37 miles mostly freeway to and from work (74 total). I played with the three settings and find I do get best MPG in sport mode as well. I am averaging 44-46 per tank, moderate to aggressive driving.
jalms is offline   Reply With Quote
Old 09-27-2012, 10:26 AM   #319 (permalink)
Klasse Act's Avatar
That's great mileage on the freeway, the best I got on the freeway was 44.6 mpg coming from northern KY to Chicago, using cruize and the car was all stock except K&N drop-in. Have you thought about trying premium too?
Welcome to the thread
Old 09-27-2012, 10:30 AM   #320 (permalink)
Yeah, I put premium in every tank.
