#21 (permalink) |
Transmission: CVT Wheels and tires: Dunlops (stock) Modifications to your car: No MPG-affecting mods Driving style: Mostly stick to speed limit, somewhat MPG-concious Typical Driving conditions: half stop-and-go traffic and half in-city highway driving Daily commute distance: approx 30 miles round trip Tire pressures: stock (32 psi?) Most common driving mode: Econ 6MT typical shift points: N/A Air conditioning use: At least 50%, and probably more Tell us anything special you do to get better fuel economy or anything you do that typically hurts your fuel economy: Steady pressure on the accelerator (and living with slowing down a bit on the uphills) and watching the mpg gauge. I drove most of a tank around the DC area in Sport and Normal modes, with a 38 mpg tank as a result. I do sometimes switch to Sport and have a bit more fun... |
#22 (permalink) |
My Fuelly stats: In sig - I think 36.1
Transmission: 6MT Wheels and tires: Stock wheels, stock Dunlop tires Modifications to your car: None Driving style: typically suburban Typical Driving conditions: Right now, very rainy Daily commute distance: 30 miles Tire pressures: haven't really checked! Most common driving mode: Normal 6MT typical shift points: Usually around the idiot light Air conditioning use: Used it alot the first week, haven't needed the last 3 weeks. Tell us anything special you do to get better fuel economy or anything you do that typically hurts your fuel economy: Just not driving like an idiot. Look ahead to coast, smooth acceleration, avoiding rush hour. [/QUOTE] |
#23 (permalink) |
My Fuelly stats: See sig
Transmission: CVT Wheels and tires: OEM Modifications to your car: K&N air filter (only the last 2,000 miles) Driving style: Calm Typical Driving conditions: Beautiful Boise weather. Daily commute distance: 66 Tire pressures: 32 Most common driving mode: ECON 6MT typical shift points: Air conditioning use: When it's above 90 degrees. Tell us anything special you do to get better fuel economy or anything you do that typically hurts your fuel economy: Just drive the speed limit. Something interesting I noticed today when I updated my Fuelly stats, I filled up 52 times in 52 weeks. Dee Dee's birthday was yesterday. |
#24 (permalink) |
This is my first post on this website, hello!
Purchased this car on Jul 4 7000 miles delivering pizza. Here's what i'm getting: My Fuelly stats:37.9 Transmission:6MT Wheels and tires:Stock Modifications to your car:Extra Wax to help MPG, Splash Gaurds Driving style izza DeliveryTypical Driving conditions:Short driving trips, in moderate traffic, all weather. Daily commute distance:~100 miles Tire pressures:Max Sidewall Most common driving mode:Sport ALL THE TIME 6MT typical shift points:Keep her below 2k when possible, Bad SoC and a hill i'll use 3k> Air conditioning use:Seldom, 15 sec defrosts here and there at night. Tell us anything special you do to get better fuel economy or anything you do that typically hurts your fuel economy:[/QUOTE] I deliver pizza which ruins it, putting forth a lot of effort, planning on getting lifetime up to 45. what do you guys think? |
#25 (permalink) |
My Fuelly stats: See Sig
Transmission: 6MT Wheels and tires: Stock Modifications to your car: None Driving style: MPG Focus Typical Driving conditions: Freeway commute Daily commute distance: 210 mi round trip, all freeway. Tire pressures: Stock (30 psi), up to 35 psi on next fill up. Most common driving mode: Econ 6MT typical shift points: 6th gear (down to 4th on hills or to charge IMA battery) Air conditioning use: None Tell us anything special you do to get better fuel economy or anything you do that typically hurts your fuel economy: cruise control. On down hill slopes, charge to 7-8 bars then coast. On uphill slopes run to IMA battery exhaustion then down to 4th gear to charge on remainder of climb. Averaging ~43 on commute; hope to get to 45 mpg. |
#26 (permalink) |
My Fuelly stats: Electra
Transmission: 6MT Wheels and tires: Stock Dunlop Modifications to your car: None Driving style: Relaxed Typical Driving conditions: Hills, and 19 mile RT on freeway to work. Daily commute distance: 22 + 6 RT for kid to school Tire pressures: 40 Most common driving mode: Econ 6MT typical shift points: Early except when in a hurry or passing a Prius. Air conditioning use: Almost None Tell us anything special you do to get better fuel economy or anything you do that typically hurts your fuel economy: Work to us auto shut off as much as possible. Watch the instantaneous mileage bars. Drive, have fun |
#27 (permalink) |
My Fuelly stats: in signature
Transmission: 6sp Wheels and tires: stock dunlops Modifications to your car: me, the driver ![]() Driving style: only excessive when merging Typical Driving conditions: great weather so far, mostly highway Daily commute distance: 60 miles each way Tire pressures: recommended pressure Most common driving mode: econ, but experimenting with normal now 6MT typical shift points: suggested shifts Air conditioning use: it's usually rockin' when the sun is out Tell us anything special you do to get better fuel economy or anything you do that typically hurts your fuel economy: i try to not eat before driving to keep the weight low |
#28 (permalink) |
My Fuelly stats/ see below
Transmission / cvt Wheels and tires / stock Modifications to your car /none at this moment Driving style / Depends if I want to get good mpg's Daily commute distance / 10 or 15 miles Tire pressures / 40 on winter tires Most common driving mode / econ Air conditioning use / none at this time. |
