What RANGE are you getting in your CR-Z? - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 10-10-2010, 06:08 PM   #1 (permalink)
Default What RANGE are you getting in your CR-Z?
Just wondering what the range is on the CR-Z (miles per tank). It has a pretty small tank at 10.6 gallons. Thanks
jynx is offline   Reply With Quote
Old 10-10-2010, 07:33 PM   #2 (permalink)
About 360 miles, but that is refueling shortly after the light comes on and putting in about 9 gallons. About 40mpg with mostly city driving.
daveNajax is offline   Reply With Quote
Old 10-10-2010, 11:39 PM   #3 (permalink)
swat49833's Avatar
I have been getting 510 miles on tank, 50.0 MPG. I forget other total miles, but I have been getting 42-51 MPG. Look at other post that I have posted thru-out the MPG forum.
swat49833 is offline   Reply With Quote
Old 10-11-2010, 12:00 AM   #4 (permalink)
Whittaker's Avatar
Good info seeing how I haven't p icked mine up yet I'd like to hear from others too. Been keeping an eye on the mpgs board but see total miles per tank is sometimes easier to comrehend
Whittaker is offline   Reply With Quote
Old 10-11-2010, 07:49 AM   #5 (permalink)
gomarlins3's Avatar
I got over 400 miles on the first tank.
Old 10-22-2010, 11:04 PM   #6 (permalink)
InsightRacer's Avatar
I got 427 on the first tank with 41.2 MPG.
I have driven Insights for the last 8 years which have similar systems. So here is how i deal with distance.
- Since its nearly a 10 gallon tank, assume you can go 10 times your current milage. In theory, you can go 10.6 times your current gas milage but the math is harder to do. So keep the 0.6 (which at 40 MPG is 24 miles), as a safety margin.
- On the Insights, I found that the tank held more than the 10.7 gallons the spec's claimed. If I ran it real close to empty, I could put more than 10.7 gallons in.
- So far (one tank) on the CR-Z, I ran it pretty close (in theory 10.4 gallons) but couldn't put 10 gallons in the tank (may have been a calibration issue at the pump).
- The miles remaining display seems to be set for the fuel remaining (as determined by the tank float gauge) and the current milage. (On the Insight, it seemed to be different. It would go to 0 and you could still drive 30 miles.) Hence, it seems pretty close. In my first encourter, it was at 3 when I got gas. There is probably still some contingency there but how much remains to be seen.
- The Refueling light goes on with 1.8 gallons remaining (according to the manual). At 40 MPG, that is 72 miles! I noticed that there was 40 miles when it went on for me.
And less gas means less weight which means better milage (but not much). So run it nearly dry but know where the next gas station is.
InsightRacer is offline   Reply With Quote
Old 10-22-2010, 11:39 PM   #7 (permalink)
angelina's Avatar
I am getting around 420 miles per tank... When I fill up I am completely topping off the neck and can put in about 10.9 gallons. I know it's a 10.6 gallon tank, but the neck must add some extra...
angelina is offline   Reply With Quote
Old 10-23-2010, 12:30 AM   #8 (permalink)
GoHuskies's Avatar
Got 320 miles today filling up with just over 8 gallons.
Old 10-28-2010, 03:52 PM   #9 (permalink)
i'm only 1/3 the way through my first tank
Old 10-28-2010, 05:08 PM   #10 (permalink)
Ecotune's Avatar
How are you doing this? Lol
2000 Honda prelude Sh
2004 Honda S2000
2011 Honda CR-Z
Ecotune is online now   Reply With Quote
