Brake question - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 01-30-2012, 08:18 PM   #1 (permalink)
Default Brake question
Looking into getting my calipers powdercoated. Question: Do my brakes need to be adjusted or aligned after I disconnect the caliper from the brake cable then reconnect it?
sandwich14 is offline   Reply With Quote
Old 01-30-2012, 11:36 PM   #2 (permalink)
Kyleseghatch's Avatar
No
<<<Anti-Fake Parts
CBP 6MT EX
My Build Thread
Old 01-31-2012, 12:18 AM   #3 (permalink)
I reccomended before doing brake work that you familiarize yourself with the process of removing the calipers, re-installing, and bleeding the system correctly. Brakes are not the simplest system on the car, but the MOST important system to not have a malfunction with.
Old 01-31-2012, 04:56 PM   #4 (permalink)
G_Man's Avatar
Second that.
I learned the hard way when I was younger. Didn't bleed the brakes properly and I had some air bubbles in my line. Luckily I wasn't going very fast when I realized I couldn't use my foot brake.
G_Man is offline   Reply With Quote
Old 01-31-2012, 05:00 PM   #5 (permalink)
Charmy82's Avatar
Originally Posted by G_Man View Post
Second that.
I too had that same aweful experience. No fun at all, that's for sure!
2011 Honda CR-Z GT
2005 Mazda RX-8 Shinka edition
Charmy82 is offline   Reply With Quote
Old 02-01-2012, 12:52 AM   #6 (permalink)
thanks for the info
Old 02-02-2012, 01:39 AM   #7 (permalink)
Caliper paint might be alot easier to do since when you are powder coating you must remove the piston and also replace the seals.
www.basissporttuning.com
1-909-740-6492
Tony@BasisSportTuning.com
Old 04-04-2012, 01:08 PM   #8 (permalink)
^Exactly. Depending on the type of powdercoat and temperature it requires to bake on, you want to make sure that the piston seals are not affected.
tempo is offline   Reply With Quote
Old 04-15-2012, 05:15 AM   #9 (permalink)
If you plan on powdercoating I suggest removing the brake dust shields from the piston or replacing them after you have them powdercoated since the process to bake powder is about 400 degrees F.
1-909-740-6492
