suspension torque specs - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 01-15-2012, 11:00 PM   #1 (permalink)
James's Avatar
Default suspension torque specs
Does anyone have the torque specs for the front and rear bolts? I'm switching my suspension tomorrow but have not been able to get the helms yet.
Looking for the front
the 2 large bolts to hub
Nut to the sway bar link
nut on the shock that bolts the bearing down to the spring seat
Top nut to the frame
And for the rear
bolt on the lower shock to axle
Top nut to frame
Got a new torque wrench for Christmas and haven't used it yet! Lmk thanks.
SSM 11' CRZ EX
Old 01-15-2012, 11:36 PM   #2 (permalink)
Koala Yummies's Avatar
Damper Pinch Bolts (front lower two bolts): 66 ft-lbs
Front Damper Hex Nut (top): 32 ft-lbs
12mm Brake Line Bolt: 16 ft-lbs
Hex Nut under the Front Shock Bushing (holds the upper spring hat down): 25 ft-lbs
Stabilizer Link ("sway"bar) to Shock: 22 ft-lbs
Rear Shock Self Locking Nut (top): 22 ft-lbs
Rear Lower Shock Bolt: 40 ft-lbs
Old 01-16-2012, 12:19 AM   #3 (permalink)
James's Avatar
Thank you Koala!!
Sohcsol I'd be careful how tight you make things, that's how bolts end up breaking/seizing eventually. But your right about the sway link but I have ways around that. Anything is possible with the right tools.
SSM 11' CRZ EX
Old 01-16-2012, 04:26 AM   #4 (permalink)
sohcsol's Avatar
Youre probably right haha. Havent broken anything so far glad somebody smarter chimed in. Ive deleted my post to reduce misinformation on the site.
Good info Koala
2011 CR-Z EX, 6MT, CBP, #7960
Old 01-16-2012, 03:22 PM   #5 (permalink)
James, you're going to have to help me redo some bolts...
Old 01-16-2012, 10:51 PM   #6 (permalink)
James's Avatar
Hahaha NP bro. I did a 1/2 ass preload on the bushings so I'm doing that ASAP tomorrow.
SSM 11' CRZ EX
Old 01-17-2012, 11:28 AM   #7 (permalink)
I may have overtightened everything. When I was putting my springs in, I was instructed to just torque everything down very tight. Not to the point of breaking anything necessarily, but I still may be too tight.
