When we bolted on the last rear strut to the car it appears that the bolt was tightened all the way down and yet the strut still has a lot of play left over. This causes an irritating banging noise when hitting sharp bumps on the road. I was wondering if anyone had ever encountered this problem and if so what you did to solve it. Please let me know!!! Below are some example pictures. how it should look ![]() how it bolted on
CR-Z Rape the world, Save the Planet!!! |
Think I had this issue with my front, clunking and all and picked it up on the test drive. I believe the whole rod was spinning. The top bolt wouldn't fully tighten down and just spun the piston rod instead of screwing in solidly. A lot of installers will pull out the impact gun, but that's done harm for me in the past with little benefit. We got really lucky and some upward pressure got the bolt to lock and stop spinning. Otherwise, I'm not sure what the solution would have been other than to uninstall and start again, which after doing a full corner weight at closing time would have been the pits.
Would love to know how other's have dealt with this, impact wrench aside. |
#4 (permalink) | |
See how much play is left on the bolt in the first picture? Grab an allen and a wrench, think it's a 14 metric. |
The thing is i am almost certain that the bolt is as tight as it can be, if you look close enough you can see that the plate above is completely bolted down to the cylinder on the strut and cant go down any further. (I apologize for the crappy picture)
Could i possibly be missing something? I read on someone's DIY that there was a rubber housing that sticks to the body of the car when you remove the factory strut, perhaps this could be missing? I only ask because the install was exactly the same on both sides yet i only have this problem on one side of the car.... (sorry for the typo's i'm on my ipad)
#7 (permalink) | |
Milano Red 6MT EX / Carbon Fiber storage lid / RCI Saftey Net / 205/45 Yokohama Advan Neova AD08s on 17x7 MB Weapons / JDP front lip and rear spoiler / Black Label Fab CAI & CAT Back / HKS Hiper Max III coilovers/ Engalls Fastcams (-2) / Hondata FlashPro Tuning / HKS Kansai Front Strut Tower Bar / Cusco Rear Strut Bar |
#8 (permalink) | |
Also, it looks like the bushing you have in that photo, is upside-down. Bushing is #6. You can see one side of the bushing is "crowned" and the other is "cupped".
#9 (permalink) | |
I guess that’s what I get for not supervising the install and just leaving it to my friends. Good catch on the rubber housing being upside down too! I’ll go over the install and let you know how it worked out! Love this forum!!!
Install completed!!!
turns out that the rubbers that go on the bottom of the car were not on the strut when my buddy installed them. (go figure) But for anyone doing an install in the future for Tein street basis I recommend putting the car on the ground first before tightening the bolts at the top of the strut so that the bottom rubber may compress for you to tighten the bolt easily. here's the finished product Tein street basis at the lowest setting.
