Anyone? both Cusco and Kansai FR Strut Tower at the same time? - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 12-15-2011, 02:11 PM   #1 (permalink)
jcrhee12's Avatar
Default Anyone? both Cusco and Kansai FR Strut Tower at the same time?
Has anyone done this or thought about doing this? Putting both the Cusco Front Strut OS Tower Bar and Kansai Strut tower bar? I figure since they mount to different parts in the front it might be interesting to see if this benefits (alternative to Spoon Cage) or if it is redundant. Thoughts?
2011 CR-Z EX 6MT
Old 12-15-2011, 06:16 PM   #2 (permalink)
JCRZ's Avatar
Waste of money, and I'd go with the hks over the cusco, cusco doesn't even mount on the strut tower.
Old 12-16-2011, 12:22 AM   #3 (permalink)
jcrhee12's Avatar
Yeah though I've heard both individually offer improvements. Thought maybe if combined would offer similar performance as say the spoon's cage.
Sent from Tapatalk
2011 CR-Z EX 6MT
Old 12-16-2011, 01:50 PM   #4 (permalink)
KamiSpeed's Avatar
should be similar results to the spoon cage, though the spoon cage is still better as it ties everything together
407-352-7024 ext: 104
Old 12-16-2011, 03:10 PM   #5 (permalink)
jcrhee12's Avatar
True.
2011 CR-Z EX 6MT
Old 12-16-2011, 03:34 PM   #6 (permalink)
KamiSpeed's Avatar
i think both are useful in some extent though I'm not sure which one is better
Old 12-17-2011, 05:04 AM   #7 (permalink)
InsightRacer's Avatar
I have thought about either and both and have the HKS on order.
If you look at the front suspension geometry, there are only 3 places (on each side) where the forces are transfered to the body: The upper shock tower mounts and the two control arm pivots at the bottom.
The bottom would be stregthened by lower strut braces, which many people have done but there is a lot of metal down there already. And I talked to an experienced road racer (some forms of road racing only allow one - either upper or lower not both) and he said the Hondas usually run the upper (suggesting that the upper is the most effective and needs more bracing than the lower).
So the upper would brace the shock towers. The HKS mounts on the shock towers so it directly addresses the problem.
The Cusco mounts on the fender/body forward of the shock tower. It's not directly attached to the key stress points and the metal that it is mounted on doesn't seem that solid (it feels solid if you push on it but it is just some bent body metal that looks like it would flex a lot more than the shock tower mount). I'm sure it does stiffen up the engine bay and people indicate it "feels" stiffer but it is not directly addressing the shock tower mount flex, only indirectly effecting it by making the overall engine bay stiffer.
That's my reasoning on the topic. YMMV!
Milano Red 6MT EX / Carbon Fiber storage lid / RCI Saftey Net / 205/45 Yokohama Advan Neova AD08s on 17x7 MB Weapons / JDP front lip and rear spoiler / Black Label Fab CAI & CAT Back / HKS Hiper Max III coilovers/ Engalls Fastcams (-2) / Hondata FlashPro Tuning / HKS Kansai Front Strut Tower Bar / Cusco Rear Strut Bar
InsightRacer is offline   Reply With Quote
Old 12-17-2011, 12:46 PM   #8 (permalink)
jcrhee12's Avatar
Thanks. It seems like Kansai is the way to go if you're only doing one bar.
Sent from Tapatalk
2011 CR-Z EX 6MT
Old 12-17-2011, 02:29 PM   #9 (permalink)
JCRZ's Avatar
the truth.
Old 12-18-2011, 08:56 AM   #10 (permalink)
i love spoon's cage. however, it wont fit the k&n intake
shootemup is offline   Reply With Quote
