Finally Eibach Pro-Kit Installed/10mm Rear Spacers - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 07-29-2011, 02:13 PM   #1 (permalink)
Jakecrxsi's Avatar
Default Finally Eibach Pro-Kit Installed/10mm Rear Spacers
I finally had my Eibach lowering springs installed, l love the way my car looks/handles the road. Here are some pictures.
Finally Eibach Pro-Kit Installed/10mm Rear Spacers-lower-cr-z-005.jpg   Finally Eibach Pro-Kit Installed/10mm Rear Spacers-lower-cr-z-010.jpg   Finally Eibach Pro-Kit Installed/10mm Rear Spacers-lower-cr-z-011.jpg   Finally Eibach Pro-Kit Installed/10mm Rear Spacers-lower-cr-z-009.jpg
Jakecrxsi is offline   Reply With Quote
Old 07-29-2011, 02:26 PM   #2 (permalink)
KamiSpeed's Avatar
looks good
407-352-7024 ext: 104
Old 07-29-2011, 07:15 PM   #3 (permalink)
Looking Good.. !
Old 07-29-2011, 07:27 PM   #4 (permalink)
are the 10mm spacers on the rear? if so, how did you install them? did you have to remove the OEM wheel studs?
'11 PWP, 6 spd, EX-Navi
Heavily braced but slightly under powered.
zeropointzero is online now   Reply With Quote
Old 07-29-2011, 09:00 PM   #5 (permalink)
Looks sick, Jake! Where did you go for the work?
716atHeart is offline   Reply With Quote
Old 07-29-2011, 09:22 PM   #6 (permalink)
bansky's Avatar
NICE !
2011 HONDA CRZ EX CVT CBP (STOCK ... FOR NOW !)
bansky is offline   Reply With Quote
Old 07-30-2011, 07:26 PM   #7 (permalink)
Jakecrxsi's Avatar
Eibach 10mm rear spacers, the long studs are included with the kit. EpicTuning did the work, they are located in Allentown, Pa. EpicTuning was feature on Last Month HondaTuning Magazine, they worked on a 4 wheeldrive Civic. Check the magazine out. They also installed the clutch for my S2000 2 years ago. Great guys. Thanks guys for the positive feedback.
Old 11-18-2011, 03:05 AM   #8 (permalink)
Loganza's Avatar
those were the exact wheels i was planning to get before i even bought my car. what size are yours? (wheels and tires please)
EDIT: nevermind i found it here: New Pictures haha gotta do research before i post not the other way around.
2011 Honda CR-Z EX w/ Navi aka Werhmacht
Loganza is offline   Reply With Quote
Old 11-23-2011, 01:34 AM   #9 (permalink)
sleighman's Avatar
Do you have any rubbing up front?
Old 11-23-2011, 01:40 AM   #10 (permalink)
Debello's Avatar
Spacers 5mm-15mm need the stock wheel studs replaced with the longer ones that come with the spacers. The 20mm spacers get bolted to the stock studs.
Debello is offline   Reply With Quote
