SHOWA Tuning Sports - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 07-15-2011, 08:30 PM   #1 (permalink)
Default SHOWA Tuning Sports
Can some of the vendors import this ?
I think coilover on a daily commuter is overkill , but that's just IMO
SHOWA TUNING HONDA CR-Z?????CR-Z?????????
woochi is offline   Reply With Quote
Old 07-15-2011, 10:10 PM   #2 (permalink)
The spoon shocks are Showa units
Old 07-18-2011, 05:25 PM   #3 (permalink)
KamiSpeed's Avatar
I can if need be...
but I think there are sufficient options available here to avoid those... at the rate the yen is right now you can get a decent set of coilovers with custom springs so its not too bad for a daily commute
407-352-7024 ext: 104
Old 07-18-2011, 08:25 PM   #4 (permalink)
Koala Yummies's Avatar
Based on the spring rates I would go with the Showa Tuning over the Spoon Fixed damper, same price wise as the Showa unit comes with springs, Spoon's are separate. I bet the Showa unit comes with the fronts pre-assembled as well. Showa made these as their own product (in addition to the OEM shocks on everyone's CR-Z), Spoon just asked Showa to build something on the side and paint them yellow so they could sell some too.
I wouldn't look at it as there being enough options to avoid this product, I was looking at these as soon as I got the CR-Z Hyper Rev book, I'm sure others are too. If I wasn't already planning on getting the Eibach coilovers, I would have already been calling around about these.
Old 07-18-2011, 10:36 PM   #5 (permalink)
I already have springs, and even though I was waiting on Bilstein, it doesn't look like it will happen. These seem like a fine option at $200 per corner. I would hope that Spoon would have Showa make a good damper for them, custom valved and all.
Showa is a MASSIVE company, one of a handful that creates dampers for the industry at large. I bet that when a large aftermarket company that makes parts specifically for Honda requests a custom damper, it's more than just a paint job.
My 2 cents....
Old 07-20-2011, 12:07 AM   #6 (permalink)
I converted the website to English and it says the spring rates are 28N/mm front and 34N/mm rear. Converted to Kgf/mm, that's only 2.8 and 3.4 respectively. Why so close to oem rates? How are you supposed to improve handling then?
2007 CIVIC EX 5MT (sold)
2011 CR-Z EX CVT (sold)
2011 CIVIC SI 6MT
sgtmorph is offline   Reply With Quote
Old 07-20-2011, 01:27 PM   #7 (permalink)
KamiSpeed's Avatar
its more than springs, its the replacement shocks... that accounts for the major difference
Old 07-20-2011, 07:00 PM   #8 (permalink)
I'm betting they have a higher psi nitrogen charge and better oil, with slightly tighter valving. That's all I want from the spoon shocks.
Old 07-20-2011, 07:43 PM   #9 (permalink)
lmk if possible ... j's racing is coming out with a set also.
Why did eibach didn't came out with a set like this ?
I just don't like the clucking and the adjusting (knowing your ride height is not perfect) part of the coilovers. If my car is a 240sx or s2000 sure I put coilovers on them .
Originally Posted by KamiSpeed View Post
I can if need be...
Old 07-21-2011, 01:22 PM   #10 (permalink)
KamiSpeed's Avatar
SHOWA TUNING SPORTS??????
the piston valve has a larger diameter, it also has a rebounding spring within the valve... some pretty awesome stuff
