Springs Springs Springs - Page 3 - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
post #21 of 52 (permalink) Old 08-12-2011, 10:40 AM
Originally Posted by northbridge View Post
Every spring will be different. The instructions will tell you what to cut. Most springs will have you cut front and rear bump stops about one inch.
If you dont cut the bump stops your car will handle poorly. Lowering reduces suspension travel, meaning you will hit the bumpstops sooner if they are the same length as stock.
What kind of problems would occur if you threw the stock springs back on with the bumpstops cut though? That is my concern.
Widget is offline
post #22 of 52 (permalink) Old 08-12-2011, 11:15 AM
the bump stops are there to help stop the shock from "bottoming out" completely and to limit the wear on suspension components when fully compressed - on stock springs your suspension would be allowed to travel further than they were designed to before you hit them so if you ever bottomed out your shocks you would be putting more wear on them.
sorry, thats not the greatest explanation. you may be able to buy stock replacement bump stops though if thats what youre concerned with.
northbridge is offline
post #23 of 52 (permalink) Old 08-12-2011, 12:02 PM Thread Starter
KamiSpeed's Avatar
The eibach ask for about 1.2 inch removed and swift about 1 inch... the tein are the smallest drop so those might require .5 inch or something so you could get away with not cutting them... but generally speaking you have to cut them... and technically speaking im sure the dealer won't notice you cut the bumpstop... they might think your suspension is messed up but they won't assume you cut the bump stop after buying springs
Kami Speed | Facebook | Instagram |
Phone Number: 1-800-821-KAMI (Available M-F 11am-7pm EST)
KamiSpeed is online now
post #24 of 52 (permalink) Old 08-12-2011, 12:07 PM
Swift seem to be giving the best results, though, correct?
I'm probably going to purchase the car after my lease is up anyway - not really worried, but just in case.
Widget is offline
post #25 of 52 (permalink) Old 08-12-2011, 02:28 PM Thread Starter
KamiSpeed's Avatar
In my opinion the Swift are the best out there...
post #26 of 52 (permalink) Old 04-26-2012, 01:06 PM
Seems like everyone prefers the Swift, what's the spring rate info on the T1R S-Coils? It's a nearly identical drop as the Swift, would love to know the spring rate to compare. Swift seems to be the stiffest so far.
Focused? is offline
post #27 of 52 (permalink) Old 04-26-2012, 01:10 PM
kenoshainflames's Avatar
t1r are made for the fit so the rear will look like its sagging. shorter spring
kenoshainflames is offline
post #28 of 52 (permalink) Old 04-26-2012, 02:24 PM Thread Starter
KamiSpeed's Avatar
there you go haha
post #29 of 52 (permalink) Old 11-16-2012, 03:00 PM
ShazzMINISTRATOR
ShazzNADES's Avatar
Stickied too. New members, please read this or the coilover comparison thread before posting another "what springs or coilovers should I get" thread.
Sent from my MB860 using Tapatalk 2
ShazzNADES is offline
post #30 of 52 (permalink) Old 04-10-2013, 12:27 PM
LSA
Old Thread, New Question
I have the Eibach Pro-Kit Springs and want to drop the car a fit further.
Too much gap in the rear. Would perfer to have a 1.2'' Drop in front and at least 1.4" in rear. Will be running 225/40/r18 Tires on 18x8 Rims. Already looks great but want to get rid of that gap. Please Help!
What Springs should I buy?
LSA is offline
