Swift Springs and alignment? - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 06-12-2011, 02:31 PM   #1 (permalink)
mechanix59's Avatar
Default Swift Springs and alignment?
For those who lowered their CRZ with the Swift Springs, did you do a wheel alignment? Is it necessary?
mechanix59 is online now   Reply With Quote
Old 06-12-2011, 03:47 PM   #2 (permalink)
dripkit's Avatar
Generally it's recommended that you get an alignment after having lowering springs installed - drive around for a week or so to get the suspension to settle then go for the alignment. I did that for my teins.
dripkit is online now   Reply With Quote
Old 06-12-2011, 04:38 PM   #3 (permalink)
Swift springs are guaranteed not to "settle," install them and go get it aligned when you have the chance.
Old 06-12-2011, 05:06 PM   #4 (permalink)
Just installed the swift springs today. No settling required for them, and for that matter, any spring that you install. Drive it down the street and do a couple figure 8's and you're set.
The Swift springs will drop about an inch and a quarter and will cause you to have extreme toe out. Get it aligned ASAP.
I based my alignment off of the Honda Fit which requires .12" degree of total toe. I personally set my car at .06" degree total toe and I am very satisfied. If you want to have control over your camber however you will need a camber kit. I was lucky enough to have no camber "issues", but mine was right on the edge, so I will be getting a camber kit when I have spare time and cash.
Hope this helps! The swift springs are nice, although the rear springs have about 5 dead coils, but everything is quiet out back on my car so no worries.
Old 06-12-2011, 07:33 PM   #5 (permalink)
JCRZ's Avatar
Yea toe gets out of wack so et it aligned
Old 06-12-2011, 11:29 PM   #6 (permalink)
darna's Avatar
I have swift and I had an alignment.
My front toe before is -0.45 adjusted to 0.
There's no adjustment at the rear though, camber is -1.6 w/c the guy said is fine.
darna is offline   Reply With Quote
Old 06-14-2011, 10:55 PM   #7 (permalink)
mechanix59's Avatar
Thanks to everyone for their input. Now, it's time to do the install. The springs just came through Fedex. So, I will do it tomorrow. I'm so excited. Thanks to my wife.
Old 06-14-2011, 11:58 PM   #8 (permalink)
Send a message via AIM to corsairmarks
If you are worried, you might go to a shop that offers a warranty on the alignment. Sears Autocenter offers 6000 miles/6months if I am not mistaken. I was able to get my vehicle aligned after replacing the struts (they were worn out, just OEM-quality replacement) and then again for free when I replaced my lower control arms/lower ball joints about a month later.
corsairmarks is offline   Reply With Quote
Old 07-18-2011, 12:29 AM   #9 (permalink)
im planning on dropping with some tein h techs soon. so just to clarify, i should get an alignment ASAP after the springs are installed? and will i need a camber kit at all?
ubnoxusCRZ is offline   Reply With Quote
Old 07-18-2011, 12:38 AM   #10 (permalink)
Should Minimally have it checked.. But, most likley will not need it at first. May need one after they settle.
Camber? No, I did not need one. Others may chime in.. But IMO not necessary.
