Camber plates needed for lowering CR-Z? - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 05-29-2011, 05:31 AM   #1 (permalink)
Murdock's Avatar
Default Camber plates needed for lowering CR-Z?
Hey guys,
I know with my previous Hondas after lowering it I had to add camber plates to adjust the camber to even it out. Do you need camber adjustment for CR-Z after lowering?
Thanks!
Murdock is offline   Reply With Quote
Old 05-29-2011, 01:15 PM   #2 (permalink)
Rear camber doesnt change much when lowering (because of the torsion beam) and neither does the front: all you would need is an alignment. There is no / very little adjustment available stock.
If you want negative camber, front camber can be changed up to about -2 by using camber bolts. Rear has nothing yet
there are threads on this already.
Old 05-29-2011, 02:42 PM   #3 (permalink)
TinTin's Avatar
also i dont think there are camber plates out for our cars yet or ever.
