If any of you own any of these coilovers, please post impressions and I will add them to the first post. Also if anyone notices a typo or other misinformation please let me know. All preliminary information gathered from pages of different vendors here or from manufacturer videos etc. *pictures will be added to this post as i get them* Criteria: Coilover Name Spring Rates Adjustability Damper Kind Drop Price Approximation Rebuildable? Reuse stock Mounts? Other information? - reviews etc * THIS IS A QUICK OVERVIEW. PRICING and OTHER SPECS MAY CHANGE * Stock! Front 2.2 kg / m Rear 3.4 kg/m Adjustability: None Damper Kind: Twin tube Drop: None Price Approximation: ? Rebuildable - Usually no: replaced by factory parts Reuse stock Mounts - NA Other information? - reviews : ask consumer reports and motor trend, lol. jk Mugen Sports Suspension Adjustable: Yes - 5 way Damper: Twin Tube? Drop: Front 1in Rear 1in (average) Price: 2000 Mounts: ? Rebuildable: ? Other Info: ![]() Tein SS Front: 3kg/m Rear: 4kg/m Adjustable: Yes: 16 way Damper: Twin Tube Drop: 1.5 inches default Price: 1200 Mounts: Re-Use stock top mounts Rebuildable: Yes at TEIN USA Other Info: Not EDFC compatible ![]() Tein MonoFlex Front: 5kg/m Rear: 5kg/m Adjustable: Yes - 16 way Damper: Mono Tube Drop: 1.5 inches default Price: 2100 Mounts: Top mounts included Rebuildable: Yes at TEIN USA Other Info: EDFC compatible. Evasive Motorsport used these coilovers on a CRZ track car that went around Button Willow. ![]() HKS Hipermax III Front: 6kg/m Rear: 5kg/m Adjustable: Yes: 30 way Damper: Mono Tube Drop: Price: 2000 Mounts: Top mounts included Rebuildable: Yes, at HKS Japan Other Info: Cusco Zero-1 Front: 6kg/m Rear: 4kg/m Adjustable: Rear can be custom ordered - default spec is not adjustable Damper: Twin Tube Drop: ? Price: 1650 Mounts: Top mounts not included Rebuildable: Yes at Cusco Japan Other Info: Custom spring rates can't be ordered. Not E-Con compatible Cusco Zero-2E Front: 6kg/m Rear: 4kg/m Adjustable: Yes - 5 way Damper: Twin Tube? Drop: ? Price: 2000 Mounts: ? Rebuildable: Yes at Cusco Japan Other Info: Custom spring rates can be ordered up to 20 kg/m. E-Con compatible ![]() ![]() Cusco Zero-3 Front: 10kg/m Rear: 9kg/m Adjustable: Yes - 24 way Damper: Mono Tube Drop: ? Price: 2700 Mounts: Included Rebuildable: Yes at Cusco Japan Other Info: Custom spring rates can be ordered up to 20 kg/m. E-Con compatible. Stiffest spring rates so far off the shelf. Tanabe Pro S0C Spring Rates? Adjustable: ? Damper: ? Drop: ? Price: ? Mounts: ? Rebuildable: Yes at Tanabe Japan Other Info: Still in R&D Eibach Pro Street-S Spring Rates: TBD Adjustability: n/a Damper Kind: Mono Tube Drop: TBD Price Approximation: $1500 Rebuildable? Yes, at Eibach USA Reuse stock Mounts? Yes Other information? - Currently being tested on Eibach's CR-Z. Tested at Buttonwillow 3 times, California Speedway once and Adams Motorsport Park once. ![]() K-Sport Kontrol Spring Rates: ? Adjustable: Yes: 36 way Damper: Mono Tube Drop: ? Price: 1000 Mounts: Top mounts included Rebuildable: *No - usually K-Sport sends new dampers instead of servicing old ones. May be different for this application Other Info: These colovers are TUV approved for those that need approval (Norway and other countries) ![]() K-Sport Rally Spring Rates: ? Adjustable: Yes: 36 way Damper: Mono Tube Drop: ? Price: 1200 Mounts: Top mounts included Rebuildable: *No - usually K-Sport sends new dampers instead of rebuilds. May be different here Other Info: These colovers are TUV approved for those that need approval (Norway and other countries) Bisimoto Coilovers Front: 350 lbs/in Rear: 650 lbs/in (dont feel like converting to kg/m - lazy, lol) Adjustable: ? Damper: Twin Tube Drop: Front 1 to 3 inches Rear: 1 to 3 inches Price: 1100 Mounts: Top mounts not included Rebuildable: Fronts yes, rears NO (replacements available for the rear) Other Info: ![]() Ground Control Sleeves Spring Rates? Adjustable: Depends on the damper you use with them Damper: Depends on the damper you use with them Drop: ? Price: 400 Mounts: N/A Rebuildable: N/A Other Info: Coilover sleeves. Can be used with stock shocks but work better with aftermarket options such as Koni yellows. Koni's are not available on this car yet. ![]() M&M Honda Front:7 kg/m Rear: 5 kg/m Adjustable: ? Damper: ? Drop: ? Price: ? Mounts: Not included by default - upgraded mounts available though Rebuildable: ? Other Info: M&M tuned Ohlins struts ![]() Bilstein Spring Rates? Adjustable: ? Damper: ? Drop: ? Price: ? Mounts: ? Rebuildable: ? Other Info: Coming soon KW Variant 1 Spring Rates? Adjustable: ? Damper: ? Drop: ? Price: ? Mounts: ? Rebuildable: ? Other Info: KW has no plans as of now to make a V2 or V3 for this application. These colovers are TUV approved for those that need approval (Norway and other countries) AJ Racing Front 6 kg/m Rear 6 kg/m Adjustable: Yes Damper: Twin Tube? Drop: Front: 35mm / Rear: 45mm Price: ? Mounts: ? Rebuildable: ? Other Info: Available now ![]() ![]() Max Racing Street Damper Kit Front: 6kg/m Rear: 5 kg/m Adjustable: ? Damper: ? Drop: ? Price: $1800 -$2000 Mounts: N/A Rebuildable: ? Other Info: MAX RACING - INFORMATION - CR-Z ![]() ![]() AMR Engineering Coilovers (pics coming soon) Adjustable: Yes - 8 way Damper: Monotube standard/ Inverted Monotube Available Spring Rate: Custom "Based on customers needs and goals for the car" Drop: 1-3 Inches Price: $1695.00 Mounts: Yes Rebuildable: Rebuildable by anyone that currently services name brand dampers such as Ohlins, Penske, Bilstein..etc. AMR also has service centers on both East and West Coasts. Other Info: Dampers come with a lifetime warranty. "We have never had a blown damper in the 6years we have been in this business. Our durability is proven, and we also use the best springs on the market made by Hyperco." Hyperco springs also have lifetime warranty from Hyperco. Dampers can be made to order Toda Fightex Coilover Adjustable: Yes (including camber adjustment) Damper: Not listed but probably monotube Spring Rate: Custom but default is 8 kg/m front and 5kg/m rear Drop: 1-3 Inches Price: $2700.00+ (they need to be imported) Mounts: No Rebuildable: Not listed ![]() Blitz Damper ZZ-R Adjustable: Yes (including camber adjustment) Damper: Monotube Spring Rate: Not listed Drop: Front 60mm // Rear 65mm Price: $2300.00+ (they need to be imported) Mounts: No Rebuildable: Yes D2 Racing Rally Adjustable: Yes 32 way Damper: Inverted Monotube Spring Rate: Not listed Drop: 1.25 inches all around Price: $1200.00+ Mounts: Yes Rebuildable: Yes D2 Racing RS Adjustable: Yes 36 way Damper: Monotube Spring Rate: Not listed Drop: Not listed Price: $900.00+ Mounts: Yes Rebuildable: Yes ![]() Interesting things: 1 - Most coilovers here have stiffer front rates compared to the rear but a few are stiffer out back. Im not sure why that is. 2 - Even some of the pricey coilovers require you to re-use stock top mounts. 3- Most common spring rate is about 6kg/m in the front and 4-5 kg/m in the rear. This may be a good starting point for comparison between brands. 4-Price of OEM Top Mounts: see post below If I forgot anything or you have information to add, post up!
25 Image limit pushes this info down to this post:
MORE COILOVERS! Megan Racing Coilovers Adjustable: Yes 32 way Damper: ? Spring Rate: ? Drop: ? Price: $1000.00+ Mounts: No Rebuildable: ? ![]() ![]() BC Racing BR-Type Coilovers Front: 4 kg/m Rear: 5kg/m Adjustability: Yes - 30 levels of damping force adjustment, adjust compression/rebound Damper: MonoTube Drop: Untested Yet Price: MSRP $1250 Rebuildable: Yes Other information?: BC Racing - North America ; Also available in "RAM-Type." These coilovers are basically the same thing except they're inverted-monotube, MSRP prices are also more expensive at $1450. ![]() Buddy Club N+ Adjustable: Yes Damper: Mono Tube Spring Rate: Front: 6kg/mm / Rear: 3kg/mm Drop: ? Price: $1150.00+ Mounts: reuse stock Rebuildable: Usually not. ![]() Corner Konnection C1 Adjustable: Yes Damper: Mono Tube Spring Rate: Custom Drop: ? Price: $1800.00 (intro price available as of 5/4/2011) Mounts: reuse stock Rebuildable: ? Other: Only available from Tony at Basis Sport Tuning as of now. Custom valved and custom spring rates on the coilovers. Picture is generic not the actual product for this application ![]() PICS Courtesy of GoTuning a forum vendor. Full suspension install instructions in the DIY section 4-Price of OEM Top Mounts: (just in case you dont want to use a spring compressor to get top mounts off or want to leave your stock suspension completely assembled. There is no problem re-using stock parts at all so this is not a necessary cost) FRONT: Front shock bearing (collar) is *$16.43 and shock mount *$17.46 each (2 needed). Total $67 Total Approx +shipping OEM vs Cusco comparison 7. For the Cusco suspension and possibly other coilovers, remove the collar from the top of the stock shock and re-use it on the Cusco Coilovers Order of assembly Rubber mount sits on top of the collar REAR Spring mount are $7.67 each, rear shock absorber washer $3.20 each, and the shock absorber mounting $3.72 each Total Approx $30 plus shipping OEM vs. Cusco (spring and perch is shown upside down) 13. Trim the tabs off of the top OEM rubber mount to install them into the cusco adjustable spring perch. 16. Make sure the stock rubber bushings are not still stuck on the body and re-install the new shock. The body of the car should be sandwiched by the 2 rubber bushings. Correct order of components with the body of the car in between the 2 rubber bushings. Vendors: Is this all we need to not have to re-use stock suspension components? I would just like to verify P.S. Thanks to College Hills Honda on the OEM pricing. Part prices are subject to change.
M&M Honda
Spring Rates: 7k front/ 5 k rear Adjustable: ? Damper: ? Drop: ? Price: 4900$ Mounts: Front and Rear available but not included Rebuildable: ? Other Info: M&M tuned Ohlin Strutw w/ springs and spring mounts/spacers, front and rear mounts extra, as are the front stabilizer links some info I could get
Certified Dealer:WedsSports, HKS, GoPro, & Swift *We will beat or match competitor's prices* 407-352-7024 ext: 104 Last edited by KamiSpeed; 02-02-2011 at 03:09 PM. |
