Camber adjustment with 1" lowering Springs - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 01-05-2011, 09:55 PM   #1 (permalink)
Default Camber adjustment with 1" lowering Springs
Can the stock parts be adjusted to handle the camber change when new springs that will result in a 1" drop are used?
This is my first "lowering" of a vehicle..
If I need to buy a camber kit in anticipation of a issue whose should I look at?
Help please?
RJ
UK007 is offline   Reply With Quote
Old 01-05-2011, 10:13 PM   #2 (permalink)
JCRZ's Avatar
You don't need a camber kit.
Old 01-05-2011, 11:00 PM   #3 (permalink)
What set-up do you have on your CRZ?
Do you have even tire wear?
I'm interested b/c I have seen it quoted that with a 1" drop the camber could be out by 1Deg. As I previously noted this is the first time I've lowered a vehicle... is 1Deg alot or within the usual set-up tolerances. How will that affect handling etc.
In my mind I tend to agree with your blanket statement.. but I'd rather just know for sure, particularly so that I know I'm not going to trash a set of tires for the sake of $100 or so.
Interested in further comments..
Thanks
RJ
Old 01-06-2011, 10:16 AM   #4 (permalink)
because of the torsion beam the rear camber doesnt change much. also someone on this board had positive camber dialed in stock... considering those two factors , i think the rear will be fine with a 1in drop. As for the front, hondas arent known to change camber too much in the front with a drop. Im not lowered yet but i seriously think you will be fine.
Old 01-06-2011, 10:50 AM   #5 (permalink)
taikahn's Avatar
1" drop? - you'll be fine. If tire wear is a worry of yours don't modify or lower your car.
2011 CR-Z EX 6MT | HKS/Cusco/BuddyClub/Honda/CorSport/OZ Racing/Dunlop
www.crzperformance.com
taikahn is offline   Reply With Quote
Old 01-06-2011, 11:53 AM   #6 (permalink)
Shatner's Avatar
You'll be fine without a camber kit. I'd still get an alignment, though.
My facebook: http://www.facebook.com/profile.php?id=100000400346832
My FB glassblowing page: http://www.facebook.com/pages/Shatne...3510224?ref=ts Check it out, see my work and 'like' my page. I make all sortsa' stuff.
Shatner is offline   Reply With Quote
Old 01-06-2011, 03:47 PM   #7 (permalink)
91CRXTC's Avatar
^^^^^That
Old 01-06-2011, 07:09 PM   #8 (permalink)
Ok thanks for the info guy.
I asked Jason (the guy running the GB on the Swift Springs) for his opinion too.. sounds like install with alignment is it... and then usual tire rotations..
RJ
Old 01-06-2011, 07:30 PM   #9 (permalink)
RJ
Concur. Have a box of Eibachs sitting in my garage waiting to be installed. Talking to my local speed/performance shop down the street - a realignment (or at least a check) is definitely needed after a drop. Camber kit will not be necessary.
