Anything is possible but I can't see that being the issue. The car is 6 months old and theres full lights all over dash and heater fan, radio, window everything just no start till engine starter kicks in... usually after turning the key on 3rd attempt. Mine is manual and I do have the clutch pedal right to the floor.
Sounds like that is my guess. I noticed everything on the dash was slow to react like the litres per 100 gauge on the canadian models.. kind like when you leave a cell phone in the cold for a bit and then use it. Well if thats the case I guess I found my first dislike with the car
When the engine starts, is it a normal start? As in the engine fires up after about a quarter of a revolution? Or does it take two or three revs before it fires? On my old 2000 MT Insight, a normal start is the same as the CRZ. When the Insight Inverter started to go south, it would take two or three revs before it would fire..
If it's a normal start, then I recommend the dealer take a look; at six months age, it would be covered under warranty. What you describe is not normal. Last winter the CRZ was snowed in for trhree weeks in freezing weather before (with my handicap) I could get to it to get it moving again. Fired up normally like 70 F rather than 35 F.
Harry 2011 Storm Silver EX CVT w/Navi & Integrated Backup Camera - Sirius/XM |
Haviruzz..It would take 2 to three revs before firing. After it started this morning for the rest of the day the IMA started it up and same as the last time. I have only seen that after sitting for 1 day untouched at cold temp when I went to drive it, I turn the key to get nothing. all lights are on the dashbright with no dimming, my fan is blowing(cause i leave it on when I shut car off) try turning the key again, same thing no crank no sound of any starting...but again all my lights are on and bright no dimming 3rd turn of the key and bang the crank crank fire of the engine.
