Rear defroster problem..? - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 12-16-2011, 04:03 PM   #1 (permalink)
Default Rear defroster problem..?
I don't think the rear defroster is working correctly. Not sure why there is gap between the two sections, but the top section on mine isn't working. See this picture.
Anyone else have this issue?
JoeJoe is offline   Reply With Quote
Old 12-16-2011, 07:51 PM   #2 (permalink)
Ludercrz's Avatar
I believe the Top section is the Radio Antenna? at least it's designed that way on older cars... I thought the radio antenna was in the shark fin though... hmm...
Old 12-16-2011, 07:53 PM   #3 (permalink)
wkqkqkfk's Avatar
Shark fins are for xm radio i think.
wkqkqkfk is online now   Reply With Quote
Old 12-16-2011, 08:01 PM   #4 (permalink)
Pretty sure the Shark fin is for the AM/FM only. The XM is in the cabin if you have it.
Others have had questions on the rear defroster and having the same issue. Here is a link to a thread here on the subject.
Rear defrost question
Old 12-16-2011, 08:52 PM   #5 (permalink)
jcrhee12's Avatar
So I just checked the service manual and what your seeing for the rear defogger is correct and functioning the way it was designed. Those wires on top of the rear glass is the "Rear Antenna Ground". Here's the description - "the rear antenna ground eliminates electro magnetic waves from the battery module to prevent noise in the AM/FM radio, and does not have a defogger function."
As stated earlier the sharkfin is the actual AM/FM antenna.
Sent from Tapatalk
2011 CR-Z EX 6MT
Old 12-16-2011, 09:17 PM   #6 (permalink)
^ Hey thanks for checking the Service Manual.. Earlier threads talked about it, but you provided the first actual explaination...
Old 12-16-2011, 10:04 PM   #7 (permalink)
wow, thanks very much for answering this.
Old 12-17-2011, 01:26 AM   #8 (permalink)
jcrhee12's Avatar
I too would not have know if it wasn't for this thread. Love this forum!
2011 CR-Z EX 6MT
Old 12-21-2011, 10:10 AM   #9 (permalink)
tanks for the description dude
snpe is offline   Reply With Quote
