just curious. i hope they do away with the auto/stop mode. i've almost had 7 or so close calls because of the engine dying on me. |
All I heard was a black interior option. Yawn.
I'm waiting for a version with sunroof - I will upgrade for that! I don't share your hate for autostop though; it's one of my favorite features and something I love about the car. Since the engine shuts down when stopping, and re-engages as soon as you get in gear, how has this caused a close call? |
also derek, i live where the temperature is usually 105 degrees almost every day with peaks over that.....and when you're at a stop light that takes a while and the car goes to sleep so does the compressor.....and that's a killer.
ya just have your AC temp set Low and it'll keep you from auto stopping. or if it does autostop it will autostart back up the second it gets a little warm.
if you're having issues with that, maybe there's something with your temp sensor, it's on the steering column above or below the key (i forget). don'T have it blocked. and Derek I'd also switch models if they had both the higher compression engine that should come hopefully in 2013 AND the "moon roof" option where the roof does not open but is just a glass. (basically the JDM and EDM version of the moonroof) |
![]() Join Date: May 2010
because of the earthquake there will be virtually no difference from the 2011 to the 2012.
As far as the heat, I just keep it on "Lo" and in SPORT mode and have had no issues at all with the auto stop shutting the car off in the heat. The CR-Z takes in different factors when deciding to auto stop or not. I have found in 95+ plus temps and with the interior temp from decent to hot it wont shut off in SPORT and set to "Lo".
