Trunk button Freezing!!? - Page 2 - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 12-08-2010, 10:06 PM   #11 (permalink)
wkqkqkfk's Avatar
Hmm, I tried spraying Sylicon Lube and it's still freezing... cant open my trunk in cold..
wkqkqkfk is online now   Reply With Quote
Old 02-05-2012, 06:00 AM   #12 (permalink)
McFaxe's Avatar
Hey guys, I've detected the same problem with the trunk switch last week.
I've also tried to warm the rubber with my fingertips but it doesn't work. I've also tried with some little heater to warm up your hands inside of clothes pockets...didn't really work...
For me it feels like the rubber's not the problem but the switch itself. The rubbers still flexibel, or I can get it flexible with my fingetips, but the switch feels like a frozen block.
Maybee moisture get's inside, freezes and blocks the movement of the switch...
It's about -5 to -15 °C in Germany those weeks, but that's obviously not cold enough to stop such parts from working. I'm going to visit my dealer tomorrow morning as the switch uses to work in the afternoon when it get's a little bit warmer outside.
I'm curious about what he'll propose to fix this problem! Every car larger than a compact car has got an electrical trunk release nowadays, especially car's >20k€.
None of my colleagues detect such a problem with their cars...
kind regards,
McFaxe
McFaxe is offline   Reply With Quote
Old 02-05-2012, 03:20 PM   #13 (permalink)
I've had several weeks of -20C or lower and never had an issue with the trunk other than ice/snow collecting in the little dip where you put your finger to hit the button.
I do not have a garage so my car is always outside. Are those of you having trunk issues parking in a heated garage,perhaps causing melting and refreezing?
61north is offline   Reply With Quote
Old 02-09-2012, 01:04 PM   #14 (permalink)
McFaxe's Avatar
So my dealer fixed it. First they couldn't imagine how this happens but after detaching the switch, they warmed it up an blew it out with compressed air.
There was probably moisture or even a little bit water between the switch and the rubber skin. As it's one part, they weren't able to seperate it, but the problem's fixed now.
They told me, that this switch hast two little drills to let the moisture out of it but maybe during washing the car, water get's into it that way...
I wash mine by hand, so you also clean the button in open trunk position. Maybe in some positions (like a open trunk) water get's inside more easily...in comparison to a closed trunk during automatic washing.....
Old 02-09-2012, 02:09 PM   #15 (permalink)
wkqkqkfk's Avatar
I fixed mine by popping out the switch (it's fitted with clips, so you can pull it out with some force), heating with a heat gun which melted all the ice and water started dripping out. after all the water is out, I used wd-40(or rubber safe lube) around the buttons and gaps in rubber so no water can get it. It worked fine ever since.
Just be careful not to spray pressure water directly in to the button part when washing your car.
Old 02-09-2012, 04:30 PM   #16 (permalink)
chaos's Avatar
Send a message via Yahoo to chaos
I had that happen Wednesday, my trunk button would not budge. It was damp and cold here. Today, it's working.
And my info panel is really slow when it's cold. It will fade and hang there a second or two until it moves on.
I haven't noticed the navigation being slow, I will look for that this weekend.
chaos is offline   Reply With Quote
Old 02-11-2012, 06:37 AM   #17 (permalink)
McFaxe's Avatar
Hey Chaos,
I also detected the info panel reacting really slow at low temperatures while the tachometer is fine like's +20°C!
I think they took different types of LCD for the info display, so that the tachometer (as most important indicator) always reacts fast!
I know that problem from my old car (Renault Twingo), but at this one the tachometer was slow at low temeperatures too! :-) Well, it was not that fast type of a car I think :-)
I've just returned from shopping and detected a new problem: The IMA sign popped up, it seems to be more a summer car...
