Gear ratios, 6 speed manual - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 07-14-2011, 12:10 PM   #1 (permalink)
carlg1212's Avatar
Default Gear ratios, 6 speed manual
Anyone else notice the ratio between 4th and 5th gear is short? Also, I'm pulling about 3000rpm @ 72mph in 6th gear...I would have thought it'd be less than that, say, around 2500rpm. I'm thinking fuel mileage. A 7th gear would be nice but I'm not sure it's necessary (I read somewhere the automatic transmission has a 7th gear?). Before I start regearing, I figured I'd ask and get some other opinions.
EDIT: the high(er) RPMs in 6th gear gives me good pickup though in the event I pass someone, can't deny that.
carlg1212 is offline   Reply With Quote
Old 07-14-2011, 12:46 PM   #2 (permalink)
At 72 mph, the car is out of it's optimal rpm range for mileage.
The CRZ is actually better than most Japanese 6 speeds when it comes to cruising rpm. In the Evo or the STi, you will be turning 2800 at around 60 if I'm not mistaken.
Old 07-14-2011, 10:36 PM   #3 (permalink)
Send a message via AIM to corsairmarks
The CVT has a 7th "gear" in the sense it gives you 7 simulated ratios in manual mode. CVT stands for Continuously Variable Transmission - the ratio changes on the fly to keep the engine near the optimal RPM for a given situation. Its essentially a belt hung between two moveable pulleys, although the ones in the CR-Z are conical. In the character of a sporty car, Honda chose to offer a manual "shift" mode on the CVT where it will try to stick in a given ratio until you tell it to shift, rather than running purely by computer control.
That said, perhaps if first gear wasn't such a big ratio (3.143) we'd have a bit more room for lower overdrive gears. Here's an article about how stuff works, straight from the horse's mouth: 2011 Honda CR-Z: Powertrain - Honda.com.
Perhaps the CVT gets better mileage because it can get all the way to .529 whereas 6th gear in the manual is .689.
corsairmarks is offline   Reply With Quote
Old 07-14-2011, 10:54 PM   #4 (permalink)
I think the 6th gear is perfect for highway, still ok for noise, and has power to pass without downshifting.
I don't like 3rd gear, going from 2nd to 3rd seems like going from 2nd to 4th.
Synapz is offline   Reply With Quote
Old 07-14-2011, 11:33 PM   #5 (permalink)
Varmint's Avatar
For reference, here are the numbers.
1st - 3.143
2nd - 1.870
3rd - 1.303
4th - 1.054
5th - 0.854
6th - 0.689
Final Drive Ratio 4.11
Around town, I frequently find myself skipping over 5th. I get up to speed using 1st through 4th, then put it in 6th to coast and maintain speed. I use 5th when passing at highway speeds, or cruising up the on-ramp.
This is how your car works
Old 07-14-2011, 11:50 PM   #6 (permalink)
I found myself doing that a few times this week. It makes great sense when trying to maintain a high average mpg.
Old 07-15-2011, 12:05 AM   #7 (permalink)
andrewr's Avatar
Yes the shift between 4th and 5th does seem a bit short if you are talking about just getting up to highway speeds one gear after another, but I get the feeling 5th gear is at the ratio it is for a slightly different purpose. I might be wrong, but the way I drive the car I come up with the understanding that 1st through 4th are acceleration gears, while 5th and 6th are both overdrives. Why two? I think because one works well in-town and one works best on the highway. I've noticed I can get some crazy high MPG numbers floating through town in 5th gear between 30-35 mph, whereas sometimes 6th can be just a bit too low for those speeds but is great for 55-60 mph. I'm also one of those people who rarely see freeway speeds, just lots of 55 mph roads and towns to slow down for.
So, yeah, my best guess in a nutshell: 1st-4th = accel gears, 5th = in-town high mpg overdrive, 6th = high mpg highway overdrive. Mind you, whether im right or not, I do average 46 mpg with that mindset
andrewr is offline   Reply With Quote
Old 07-15-2011, 12:57 AM   #8 (permalink)
Originally Posted by andrewr View Post
.... 1st-4th = accel gears, 5th = in-town high mpg overdrive, 6th = high mpg highway overdrive. Mind you, whether im right or not, I do average 46 mpg with that mindset
I think 5th is for top speed.
CR-Z owner since 24th August, 2010
Tein SS, Spoon throttle body, Motul RBF 600, Basis 2.25" Test Pipes
http://www.flickr.com/photos/fearrange/ http://fearrange.smugmug.com/
human668 is online now   Reply With Quote
Old 07-20-2011, 08:30 AM   #9 (permalink)
carlg1212's Avatar
Yeah man, thanks for the suggestion. This morning, I geared through 1-2-3, then @ 40mph in 3rd went right to 5th, and it worked out well. Totally skipped 4th gear altogether.
Old 07-21-2011, 10:01 AM   #10 (permalink)
dntower85's Avatar
That is a bit short for the Hwy, The CVT is lower around 2200-2400 in Eco mode I think.
But it isn't as bad as my S2K which is at 4000 rpms at 80 in 6th. Buzzzzzzzzzzzzzzzzzz Its like riding a motorcycle you go 100miles then you want to stop for a few hours.
2011 North Shore Blue CR-Z CVT
2001 Honda S2000
2000 Honda 125cc Shifter Kart
dntower85 is offline   Reply With Quote
