#21 (permalink) |
![]() Join Date: Apr 2010
5x...?
http://promo-code.be (sorry, only in Dutch or French) |
#22 (permalink) |
PDC: 5x114,3
Offset: 45 on all OEM wheels Size: 6x16 and optional 6.5x17 Tires: 195/55R16 or 205/45R17 Tire brand: Bridgestone This is EDM spec but I expect no difference to the USDM models. http://www.honda.de/tyrepdf/de/zf_crz.pdf
#24 (permalink) | |
You know the optional 17 inch specs? |
#26 (permalink) |
Knowing nothing about wheels other than the obvious, do the 17" wheels give more grip? Is there more tire in contact with the road? Do they fill up more of the wheel arch (or is the tyre thinner than the one used on the 16"?).
Or are the only three things you get from the 17" wheels: looks nice, less mpg, lighter wallet? |
#28 (permalink) |
I will be running this wheel...
16x7 - 5x114.3 - 43 ET - 13.7 LBS Or 17x7 - 5x114.3 - 45 ET - 14.6 LBS If you want to see available sizes...here you go. http://www.enkei.com/size_chart/RPF1.pdf
