#11 (permalink) |
#12 (permalink) |
OKay Nice install. I was concidering doing something like this on my next vehicle cause I am a ham radio operator and it would be nice to have a sturdy mount that I can put on to hold a HF antenna they can be a bit bulky. but I am wondering, a friend of mine said never to get a bolt on hitch, that you always want it welded on. Any comments on this.... I will probably use it for at most 25 pound bicycle or for my antenna which weigh less. Ho much does this thing weight empty... does it add about 40 to 60 pounds to the car having it on there.... Is there a difference between brands out there any comments on this will help me weight my decision. Thanks, Ron
#13 (permalink) |
I didn't really put the hitch on the scale before the installation, but I'm guessing its approx. 50lbs on its own, the bike rack i put on is approx. 25-30lbs.
Originally I wants to install the more famous brand 'Hidden Hitch', but they don't even have the system for CR-Z, and I end up found 'Curt Manufacturing' Product #11077 and got it online approx. for $120, and took it to install at my friends' garage.
2000 Acura 1.6EL MT Silver 2003 Honda EP3 SiR MT Blue 2011 Honda CR-Z MT White |
#15 (permalink) |
The hitch installation looks great!
Just to note, the car manual states that the maximum load for our cars is only 400lbs / 181kg (check p. 194 or the label in the driver's side doorjamb). Not a whole lot of breathing room after you stick two North American sized adults in there
#16 (permalink) | |
it does sag a bit like the hitch opening is pointing downward (slight angle) instead of flat. but I do not have any issue even with the rack is on, due to the rear axle is so close to the rear bumper, even a high speed bump or going up/down to underground garage still perfectly fine to me (I'm living in a condo, up/down the ramp every single day), also had been to multiple road trips, gravel road or muddy light off-road condition with the hitch and don't have any issue at all. i'll post a picture up after the weekends with some measuring tape to show how much mine sag with the rack is on.
#17 (permalink) | |
#19 (permalink) | |
![]() Join Date: Aug 2011
You are definitely going to void your warranty.....serious. doh, i re-read a few posts up, you should be fine. |
