Will 2013 LED DRL headlights plug and play on a 2011 EX? - Page 5 - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Go Back   Honda CRZ Forum: Honda CR-Z Hybrid Car Forums > Honda CR-Z: Technical > Exterior Modifications
Old 02-05-2013, 01:51 PM   #41 (permalink)
Ludercrz's Avatar
like I said i'm sure there's something that is more "stock-ish" by changing the relay or splicing in one of the relays, just need to test them and find out what port will give the desired result. without having to pass a wire through the firewall or remove/tap fuses.
If someone wants to buy me a set of headlights i'll be glad to test all the wirings
Old 02-08-2013, 12:38 AM   #42 (permalink)
Originally Posted by JeTLiX View Post
Screw it. Imma yolo this, order the 2013 headlights and see if they fit. Taking one for the team
That's mah boy!
11 PWP CR-Z EX 6MT
chiggah is offline   Reply With Quote
Old 02-09-2013, 06:03 PM   #43 (permalink)
Default Update on the DRL operation...for our 2011, 12's...
Finally got a chance to check out a 2013 EX and the headlight operation. The DRL's come on as usual when ignition is on and em brake released, and stay on with the parking lights, but go out when the headlights are energized. I can see why they do this as they are very bright by themselves and aren't needed with the headlights. So now if we can find a 12v connection for the LED DRL's it should have a switch also. Problems, problems.
Someone said to run a connection thru-the-firewall to a vacant fuse and install a switch to de-energize the DRL's when lights are on. Anybody got a DIY for this thru-the-firewall and fuse connection install? Doesn't sound easy for us big OLD guys!
oldfartinalude is offline   Reply With Quote
Old 02-10-2013, 05:49 PM   #44 (permalink)
Ludercrz's Avatar
if I could get the headlights for 500$ for both i'd do it and figure out the wiring easily... unfortunately i still find it expensive at over 700.
Old 02-19-2013, 04:40 PM   #45 (permalink)
I'm ready to pull at $650 lol.
I gotta find someone in Socal to install + do all the electrical stuff for me. I'm probably looking at $800 total maybe?
If anyone is familiar with this type of install...I don't mind buying at current price and be the guinea pig of a DIY thread : )
ubiquitous5 is offline   Reply With Quote
Old 03-08-2013, 11:23 PM   #46 (permalink)
I don't know if this helps, but here in Aus the LED daytime running lights are standard on the 2011 model and have always been. Not totally necessary to try and source a 2013 set, but yeah probably expensive just like all the other sources out there.
They connect to fuse 15. They are always on and come on with accessories and dim when the headlights / high beams are on. As far as wiring I can't tell as it's quite tight in there. If i get a chance I'll get some detailed photos of them and try to trace the wiring.
The headlight levelling comes from a dial (that I believe is missing from the USDM dash) on the dash on the same side as the 3-mode switches, shown here:
http://crz.honda.com.au/resources.as...rz_3button.jpg
It's a button, but only comes out to make it easier to turn. The manual states to push it in only to prevent accidentally changing it. It also states that the models that come with HID headlights are auto levelling.
They are auto activating though...
Rayder is offline   Reply With Quote
Old 03-09-2013, 11:36 AM   #47 (permalink)
Koala Yummies's Avatar
Where in Socal are you?
Tapping in to the fuse box and adding a switch would be super simple.
But doing it the OEM way (DRLs on when handbrake is dropped) would not be difficult either. I can scour the firewall for a suitable grommeted-hole.
Old 03-20-2013, 05:51 PM   #48 (permalink)
stEVOVIII's Avatar
Send a message via AIM to stEVOVIII Send a message via Skype™ to stEVOVIII
Koala Yummies will do the install, and I will buy your stock headlight housings!!!
stEVOVIII is offline   Reply With Quote
Old 03-21-2013, 12:52 PM   #49 (permalink)
Ludercrz's Avatar
hmm... how much will you buy 2011-2012 HID stock headlights for?
i'd buy 2013 ones and wire them if i could get a good turn around on the stock ones. i just don't know how much they would be worth.
Old 04-18-2013, 08:43 PM   #50 (permalink)
joevincent's Avatar
Here's another thought, I have a 2013 base model and want to switch over to the EX headlights, I wonder if mine would be in the same boat as you guys or if mine is plug in play. What do you guys think?
2013 Honda CR-Z
1987 BMW 325 (E30)
"Live Loud. Never Dead."
joevincent is offline   Reply With Quote
