Redline - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 01-15-2012, 10:14 AM   #1 (permalink)
carlg1212's Avatar
Default Redline
I have a 6MT, and I think I redlined, maybe I was a little below (definitely below 7000rpm). What damage happens if you redline for ~2 seconds? I've done this one other time now I'm thinking of granny driving for the life of the car.
"The value of life can be measured by how many times your soul has been deeply stirred." - Soichiro Honda
carlg1212 is offline   Reply With Quote
Old 01-15-2012, 10:52 AM   #2 (permalink)
Erm no damage the rev limiter would have stopped it causing any damage unlessmthe CRZ is different in some respect. If however you changed down into too low a gear at high speed causing it to redline this is known as buzzing the engine and can cause damage but your descrbing the former. Its very easy to hit the limiter in the Crz in first and second youll do it again stop worrying as long as the cars warmed up first.
pwood is offline   Reply With Quote
Old 01-15-2012, 11:20 AM   #3 (permalink)
Yeah, happens to me fairly often.. If I'm having fun getting up to speed on the highway or something and not paying attention to my revs, all of a sudden it's bouncing off the limiter. Sad when you run out of steam like that, and aren't expecting it.
wicked1 is online now   Reply With Quote
Old 01-15-2012, 11:34 AM   #4 (permalink)
Agreed, the limiter is there to ensure you're safely driving it.
If Honda argued that you ran on the limiter for extended periods of time and refused warranty work, I'd be firing up a lawsuit. They set the rules on that one.
Widget is offline   Reply With Quote
Old 01-15-2012, 05:19 PM   #5 (permalink)
carlg1212's Avatar
Didn't realize the MT had a rev limiter. Cool.
Old 01-15-2012, 06:04 PM   #6 (permalink)
Kyleseghatch's Avatar
REV HARD MAN!! It's under warranty! Blow that BISH!
<<<Anti-Fake Parts
CBP 6MT EX
My Build Thread
Old 01-15-2012, 07:06 PM   #7 (permalink)
91CRXTC's Avatar
If I catch you grannying that Z I will confiscate that ish, be a driver not a rider.
Old 01-16-2012, 10:50 PM   #8 (permalink)
Old School's Avatar
Nothing to worry about, I have bounced mine of the rev limiter a few times as well. It just means you are driving as you should.
Old School is online now   Reply With Quote
Old 01-17-2012, 10:56 AM   #9 (permalink)
carlg1212's Avatar
Thanks to everyone for clarifying. If I damaged her, I'd be so freakin' pissed at myself.
But now, I have renewed confidence since I realize Honda has factored in redlining. And that means I can let 'er rip!
Check out my video if you haven't already. Listen to her roar. I usually don't listen to rap but I like some of the older stuff
Honda CR-Z w/ K&N Typhoon intake and Black Label Fabrication exhaust - YouTube
Old 03-14-2012, 09:01 PM   #10 (permalink)
majestic's Avatar
The rev limiter is simply there as a safety issue. Hondas can handle a rev far higher than what the limiter is set to. My rsx limiter was at somewhere around 8k and Hondata pushed it far beyond that to almost 9k. These engines are bulletproof. Same with the s2000. Hondas love to rev
Now, if you miss a gear and misshift, say, from redlining 3rd and forcing it back to 2nd, then that's when you're screwed. something that happened way too often in the rsx community. No limiter can save you there.
CBP 6spd EX
majestic is offline   Reply With Quote
